Black Hole - Benchmark (OLD Version)
Status
Not open for further replies.
Just for the second place :P
4.7ghz (bumped voltage a bit too high, just to be sure it would be stable enough. Did it quick in AI suite lol)
You should! :D
Its only about two minutes of work :P
Hmm maybe, I was going to do it now, but IIRC my board has issues with it.
I'm using the pre-set ASUS overclock at the moment, shame on me I know, but I don't have time to go changing voltages and running hours of stability testing.
I like the new version. Really simple logging results!
I only ran it at my current overclock (4.2), but you should at least get some more data :).
Jet, I need you to test again. Your scores are too low for 4.2ghz, did you run any programs while testing?
And for all other testers: "RUN THE BENCH WITH ALL OTHER PROGRAMS OFF, EVEN BACKGROUND PROCESSES!!!!"
It's just irritating, because then I can't know real results....
So with your new database I no longer need to post it here :P
You're not in the database for some reason, did you fill it in wrong or didn't click the "send" button?
The rest who said here that they posted in database, are in.
That's pretty toasty...
Nah for a 2500K 68C max is fine. My old i5 760 used to max at about 70-75C with the stock cooler and at stock clocks and it worked fine, I also had an old Core 2 Quad Q8300 which used to do the same.
Status
