windows 8
jzombek6
hello everyone
recently installed win 8 and am not quite liking it just yet.
heres what I would like to do,not sure if it can be done and also need assistance in doing it if it can.
installed a new internal hard drive that I would like to install win 7 , giving me option of using win 7 while using win 8 while getting used to it. I have some programs that do not work on 8 and cannot find drivers for them. one piece of software is micro visio. visio uses a lot of memory and thought if I can use it on a 2nd drive without a lot of software it may work better. I have a 64 bit,4g ram on my system.
can you give me direction on how to accomplish this.
thanks
couple of thing I forgot to mention
best buy people said if u use dual booting,when u boot to win 7,it will wipe out win8.
also,do I need to configure one as master,one slave-they are sata drives.
Using it on a second drive wont help...if anything, it may slow down as the computer is having to read two drives. I dont really understand what you are trying to do though...can you explain more?
No it won't...
@OP, what you are talking about is dual booting, which can be done.
Before you install any OS, Partition your hard drive into at least 2 partitions. You may want 3, with the third having files/folders that you will regularly use/need, such as music, videos, office files etc.
Install Windows 7 first on one partition, then install Windows 8 on the other. When you boot up you will then have the choice of Windows 7 or 8.
Alternatively, installed just Windows 7 and then run Windows 8 in a virtual machine
I'd just install it in a virtual machine. That way, if you don't like it, you can just delete the virtual machine in a matter of seconds. Removing the Windows 8 partition etc will take longer.
A matter of minutes instead?
Format Partition
Expand primary partition
I, personally, would dual boot. You have better compatibility (generally speaking) than in a VM and you have all of the power available
The good thing about that is that if you have Windows 7 Enterprise or Ultimate, you can chose to boot from the Virtual HDD file!
