So I'm upgrading from a Thermaltake Commander to the NZXT Phantom. My current case only has one fan, and I was wondering if I could remove it and install it into the Phantom? From what I've heard, some of the fans on the phantom need to be made by NZXT in order to fit correctly. Will a (I assume) standard 120mm fan fit in the Phantom? Where would I install it?
Thanks for the help.
