turbobooster
hello hopfully i can change my gtx 660ti tomorrow to the club3d joker card, has sombody of you any expirience with this card.
and can you tell me how you like it.
Why do you need the change if you know 7850<gtx660<hd7870 ghz ed.< gtx660ti < hd7950 boost...
i just like amd and the joker card is normally faster then a 7950, not the bus width and the mem i know that but performence wise.
and i have a crossfire bord so will upgrade verry soon after this 1.
Club3D is a well known brand, just not in America.
Even if an hd7870 is clocked very high, it would be only a bit faster. While the hd7950 boost is even faster. + at resolutions about 1080p is the 660ti only 3-5% slower where the hd7870 will be like 19%.
But ok, your choice...
don't know this card, maybe you could link to it?
I wouldnt go for a brand like that, i'd rather stick to the well known good brands.
so i have now the 7870 club 3d jokercard now, its alot faster then tyhe normal 7870
Benchmarks mean nothing though unless you get all hot and flustered just thinking about bigger numbers on the screen.
I am on about real world performance. What FPS difference is there in games, can you push higher settings now whilst maintaining the same FPS, do you get more PPD in F@H and how many for example
It is a good job it is a well known brand then, isn't it
They are European, hence why you haven't heard of them. At some point in your life you hadn't heard of Evga, Gigabyte, XFX, PNY, Zotac, PowerColor, MSI, Asus or any other manufacturer, yet had to go for one or the other. People told you they were good and that is the only reason you went for them.
Rather than assume now I haven't heard of this, it must be bad, do a bit of research yourself, otherwise you will miss out on a hell of a lot.
At what resolution? When compared to a 7950, the 7870 isn't hugely more powerful except at higher resolutions (over 1920x1080). Tbh I wouldn't expect anything more than a placebo right now.
If you still have your 7870, care to do a few benchmarks to see what the performance difference actually is?
Now I read that link I'm pretty interested in this. Could you post up a pic with 3dmark11 results at the jokers normal speed? Want to know where it lays between the hd7870 and 7950...
I'll post mine to compare.
I never heard of that company before either. Don't know if they're good or bad company. I think it's more of a Europe company or something.
If it's a well know "Brand", why is it new to us in America?
