I would suggest scanning your system for malware using Malwarebytes and also checking for boot infections using tdsskiller.
1.
Please download and run
TDSSkiller
When the program opens, click on the start scan button.
TDSSKiller will now scan your computer for the TDSS infection. When the scan has finished it will display a result screen stating whether or not the infection was found on your computer. If it was found it will display a screen similar to the one below.
To remove the infection simply click on the Continue button and TDSSKiller will attempt to clean the infection.
When it has finished cleaning the infection you will see a report stating whether or not it was successful as shown below.
If the log says will be cured after reboot, please reboot the system by pressing the reboot now button.
After running there will be a log that will be located at the root of your c:\ drive labeled tdsskiller with a series of numbers after it. Please open the log and copy and paste it back here.
2.
Please download
Malwarebytes' Anti-Malware from
here or
here and save it to your desktop.
- Double-click mbam-setup.exe and follow the prompts to install the program.
- At the end, be sure a checkmark is placed next to
- Update Malwarebytes' Anti-Malware
- and Launch Malwarebytes' Anti-Malware
- then click Finish.
- If an update is found, it will download and install the latest version. Please keep updating until it says you have the latest version.
- Once the program has loaded, select Perform quick scan, then click Scan.
- When the scan is complete, click OK, then Show Results to view the results.
- Be sure that everything is checked, and click Remove Selected.
- A log will be saved automatically which you can access by clicking on the Logs tab within Malwarebytes' Anti-Malware
If for some reason Malwarebytes will not install or run please download and run
Rkill.scr,
Rkill.exe, or
Rkill.com. If you are still having issues running rkill then try downloading these renamed versions of the same program.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
But
DO NOT reboot the system and then try installing or running Malwarebytes. If Rkill (which is a black box) appears and then disappears right away or you get a message saying rkill is infected, keep trying to run rkill until it over powers the infection and temporarily kills it. Once a log appears on the screen, you can try running malwarebytes or downloading other programs.
Download the
HijackThis installer from
here.
Run the installer and choose
Install, indicating that you accept the licence agreement. The installer will place a shortcut on your desktop and launch HijackThis.
Vista and Windows 7 users must right click on the hijackthis icon and click on run as. If the run as option doesn't appear then press and hold the shift key while right clicking on the icon to get it to appear.
Click
Do a system scan and save a logfile
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
the unlocker worked, it deleted that file from the folder, but i still scanned with tdskiller( no viruses were found ) and malwarebyte ( it found 6 malwares which i removed ) i attached all logs in the archive file here. hope it removed everything. Can you tell me what the logs mean?
later edit: hijack this file
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 14:50:30, on 06/02/2013
Platform: Windows 7 SP1 (WinNT 6.00.3505)
MSIE: Internet Explorer v9.00 (9.00.8112.16450)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\ASUS\ASUS Live Update\LiveUpdate.exe
C:\Program Files (x86)\ASUS\ATK Package\ATKOSD2\ATKOSD2.exe
C:\Program Files (x86)\ASUS\FaceLogon\sensorsrv.exe
C:\Program Files (x86)\ASUS\USBChargerPlus\USBChargerPlus.exe
D:\Files&Shit\Malwarebytes' Anti-Malware\mbamgui.exe
C:\Program Files (x86)\DAEMON Tools Pro\DTShellHlp.exe
C:\Program Files (x86)\Google\Drive\googledrivesync.exe
C:\Program Files (x86)\Microsoft Office\Office14\MSOSYNC.EXE
C:\Users\Weedy\AppData\Roaming\Dropbox\bin\Dropbox.exe
C:\Program Files (x86)\ASUS\ATK Package\ATK Media\DMedia.exe
C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\HControlUser.exe
C:\Program Files (x86)\ASUS\Wireless Console 3\wcourier.exe
C:\Program Files (x86)\ASUS\Splendid\ACMON.exe
C:\Program Files (x86)\Creative\THX TruStudio\THXNBSet\THXAudNB.exe
C:\Windows\AsScrPro.exe
C:\Program Files (x86)\Roxio\CinePlayer\5.0\CPMonitor.exe
C:\ExpressGateUtil\VAWinAgent.exe
C:\Program Files (x86)\Yahoo!\Messenger\ymsgr_tray.exe
C:\Program Files (x86)\PowerISO\PWRISOVM.EXE
C:\Windows\SysWOW64\ACEngSvr.exe
C:\Program Files (x86)\Winamp\winampa.exe
C:\Program Files (x86)\AVG\AVG2012\avgtray.exe
C:\Program Files (x86)\AVG Secure Search\vprot.exe
C:\Users\Weedy\AppData\Local\Google\Chrome\Application\chrome.exe
D:\Files&Shit\hijack\Trend Micro\HiJackThis\HiJackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page =
http://cool-itv.net
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=userinit.exe,
O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files (x86)\Yahoo!\Companion\Installs\cpn1\yt.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: BitComet ClickCapture - {39F7E362-828A-4B5A-BCAF-5B79BFDFEA60} - C:\Program Files\BitComet\tools\BitCometBHO_1.5.4.11.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files (x86)\AVG\AVG2012\avgssie.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\PROGRA~2\MICROS~2\Office14\GROOVEEX.DLL
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre7\bin\ssv.dll
O2 - BHO: IESpeakDoc - {8D10F6C4-0E01-4BD4-8601-11AC1FDF8126} - C:\Program Files (x86)\Bluetooth Suite\IEPlugIn.dll
O2 - BHO: AVG Security Toolbar - {95B7759C-8C7F-4BF1-B163-73684A933233} - C:\Program Files (x86)\AVG Secure Search\14.0.0.14\AVG Secure Search_toolbar.dll
O2 - BHO: SkypeIEPluginBHO - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O2 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\PROGRA~2\MICROS~2\Office14\URLREDIR.DLL
O2 - BHO: DownTango Launcher - {b52d0735-ec19-448a-abde-e01b5bd275d2} - C:\Users\Weedy\AppData\Roaming\DownTangoLauncherToolbar\DownTangoLauncherToolbar.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre7\bin\jp2ssv.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files (x86)\Yahoo!\Companion\Installs\cpn1\yt.dll
O3 - Toolbar: DownTango Launcher - {b52d0735-ec19-448a-abde-e01b5bd275d2} - C:\Users\Weedy\AppData\Roaming\DownTangoLauncherToolbar\DownTangoLauncherToolbar.dll
O3 - Toolbar: AVG Security Toolbar - {95B7759C-8C7F-4BF1-B163-73684A933233} - C:\Program Files (x86)\AVG Secure Search\14.0.0.14\AVG Secure Search_toolbar.dll
O4 - HKLM\..\Run: [ATKOSD2] C:\Program Files (x86)\ASUS\ATK Package\ATKOSD2\ATKOSD2.exe
O4 - HKLM\..\Run: [ATKMEDIA] C:\Program Files (x86)\ASUS\ATK Package\ATK Media\DMedia.exe
O4 - HKLM\..\Run: [HControlUser] C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\HControlUser.exe
O4 - HKLM\..\Run: [Wireless Console 3] C:\Program Files (x86)\ASUS\Wireless Console 3\wcourier.exe
O4 - HKLM\..\Run: [ACMON] C:\Program Files (x86)\ASUS\Splendid\ACMON.exe
O4 - HKLM\..\Run: [THX TruStudio NB Settings] "C:\Program Files (x86)\Creative\THX TruStudio\THXNBSet\THXAudNB.exe" /r
O4 - HKLM\..\Run: [UpdReg] C:\Windows\UpdReg.EXE
O4 - HKLM\..\Run: [ASUS Screen Saver Protector] C:\Windows\AsScrPro.exe
O4 - HKLM\..\Run: [CPMonitor] "C:\Program Files (x86)\Roxio\CinePlayer\5.0\CPMonitor.exe"
O4 - HKLM\..\Run: [VAWinAgent] C:\ExpressGateUtil\VAWinAgent.exe
O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files (x86)\PowerISO\PWRISOVM.EXE -startup
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files (x86)\Winamp\winampa.exe"
O4 - HKLM\..\Run: [BCSSync] "C:\Program Files (x86)\Microsoft Office\Office14\BCSSync.exe" /DelayServices
O4 - HKLM\..\Run: [FLxHCIm64] "C:\Program Files\Fresco Logic\Fresco Logic USB3.0 Host Controller\amd64_host\FLxHCIm.exe"
O4 - HKLM\..\Run: [AVG_TRAY] "C:\Program Files (x86)\AVG\AVG2012\avgtray.exe"
O4 - HKLM\..\Run: [vProt] "C:\Program Files (x86)\AVG Secure Search\vprot.exe"
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKCU\..\Run: [Google Update] "C:\Users\Weedy\AppData\Local\Google\Update\GoogleUpdate.exe" /c
O4 - HKCU\..\Run: [Messenger (Yahoo!)] "C:\Program Files (x86)\Yahoo!\Messenger\YahooMessenger.exe" -quiet
O4 - HKCU\..\Run: [GoogleDriveSync] "C:\Program Files (x86)\Google\Drive\googledrivesync.exe" /autostart
O4 - HKCU\..\Run: [OfficeSyncProcess] "C:\Program Files (x86)\Microsoft Office\Office14\MSOSYNC.EXE"
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-21-1125771683-1592405453-3275235758-1007\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'UpdatusUser')
O4 - HKUS\S-1-5-21-1125771683-1592405453-3275235758-1007\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'UpdatusUser')
O4 - Startup: Dropbox.lnk = Weedy\AppData\Roaming\Dropbox\bin\Dropbox.exe
O8 - Extra context menu item: &D&ownload &with BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddLink.htm
O8 - Extra context menu item: &D&ownload all with BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddAllLink.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~2\Office14\EXCEL.EXE/3000
O8 - Extra context menu item: Se&nd to OneNote - res://C:\PROGRA~2\MICROS~2\Office14\ONBttnIE.dll/105
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra button: (no name) - {45d8438c-b51d-47a8-aeea-9061535f25f1} - C:\Users\Weedy\AppData\Roaming\DownTangoLauncherToolbar\DownTangoLauncherToolbar.dll
O9 - Extra button: (no name) - {7815BE26-237D-41A8-A98F-F7BD75F71086} - C:\Program Files (x86)\Bluetooth Suite\IEPlugIn.dll
O9 - Extra 'Tools' menuitem: Send by Bluetooth to - {7815BE26-237D-41A8-A98F-F7BD75F71086} - C:\Program Files (x86)\Bluetooth Suite\IEPlugIn.dll
O9 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIELinkedNotes.dll
O9 - Extra 'Tools' menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIELinkedNotes.dll
O9 - Extra button: Skype Click to Call - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O9 - Extra button: BitComet - {D18A0B52-D63C-4ed0-AFC6-C1E3DC1AF43A} - res://C:\Program Files\BitComet\tools\BitCometBHO_1.5.4.11.dll/206 (file missing)
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O16 - DPF: {6C269571-C6D7-4818-BCA4-32A035E8C884} (Creative Software AutoUpdate) -
http://ccfiles.creative.com/Web/softwareupdate/su/ocx/15102/CTSUEng.cab
O16 - DPF: {D4B68B83-8710-488B-A692-D74B50BA558E} (Creative Software AutoUpdate Support Package 2) -
http://ccfiles.creative.com/Web/softwareupdate/ocx/15113/CTPIDPDE.cab
O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} (Creative Software AutoUpdate Support Package) -
http://ccfiles.creative.com/Web/softwareupdate/ocx/121022/CTPID.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files (x86)\AVG\AVG2012\avgpp.dll
O18 - Protocol: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~2\COMMON~1\Skype\SKYPE4~1.DLL
O18 - Protocol: viprotocol - {B658800C-F66E-4EF3-AB85-6C0C227862A9} - C:\Program Files (x86)\Common Files\AVG Secure Search\ViProtocolInstaller\14.0.1\ViProtocol.dll
O18 - Filter hijack: text/xml - {807573E5-5146-11D5-A672-00B0D022E945} - C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE14\MSOXMLMF.DLL
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: ASLDR Service (ASLDRService) - ASUS - C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\ASLDRSrv.exe
O23 - Service: Asus process privilege adjust service (AsusUacSvc) - Unknown owner - C:\Program Files\Asus\Rotation Desktop for G Series\AsusUacSvc.exe
O23 - Service: AtherosSvc - Atheros Commnucations - C:\Program Files (x86)\Bluetooth Suite\adminservice.exe
O23 - Service: ATKGFNEX Service (ATKGFNEXSrv) - ASUS - C:\Program Files (x86)\ASUS\ATK Package\ATKGFNEX\GFNEXSrv.exe
O23 - Service: AVG Firewall (avgfws) - AVG Technologies CZ, s.r.o. - C:\Program Files (x86)\AVG\AVG2012\avgfws.exe
O23 - Service: AVGIDSAgent - AVG Technologies CZ, s.r.o. - C:\Program Files (x86)\AVG\AVG2012\AVGIDSAgent.exe
O23 - Service: AVG WatchDog (avgwd) - AVG Technologies CZ, s.r.o. - C:\Program Files (x86)\AVG\AVG2012\avgwdsvc.exe
O23 - Service: BitComet Disk Boost Service (BITCOMET_HELPER_SERVICE) -
www.BitComet.com - C:\Program Files\BitComet\tools\BitCometService.exe
O23 - Service: Creative ALchemy AL6 Licensing Service - Creative Labs - C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\AL6Licensing.exe
O23 - Service: Creative Audio Engine Licensing Service - Creative Labs - C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\CTAELicensing.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: FLEXnet Licensing Service 64 - Flexera Software, Inc. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService64.exe
O23 - Service: Futuremark SystemInfo Service - Futuremark Corporation - C:\Program Files (x86)\Futuremark\Futuremark SystemInfo\FMSISvc.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Google Update Service (gupdatem) (gupdatem) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: LogMeIn Hamachi Tunneling Engine (Hamachi2Svc) - LogMeIn Inc. - C:\Program Files (x86)\LogMeIn Hamachi\hamachi-2.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Intel(R) Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service: MBAMScheduler - Malwarebytes Corporation - D:\Files&Shit\Malwarebytes' Anti-Malware\mbamscheduler.exe
O23 - Service: MBAMService - Malwarebytes Corporation - D:\Files&Shit\Malwarebytes' Anti-Malware\mbamservice.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @C:\Program Files (x86)\Nero\Update\NASvc.exe,-200 (NAUpdate) - Nero AG - C:\Program Files (x86)\Nero\Update\NASvc.exe
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: NVIDIA Update Service Daemon (nvUpdatusService) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core\daemonu.exe
O23 - Service: PnkBstrA - Unknown owner - C:\Windows\system32\PnkBstrA.exe
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Skype C2C Service - Skype Technologies S.A. - C:\ProgramData\Skype\Toolbars\Skype C2C Service\c2c_service.exe
O23 - Service: Skype Updater (SkypeUpdate) - Skype Technologies - C:\Program Files (x86)\Skype\Updater\Updater.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
O23 - Service: TeamViewer 8 (TeamViewer8) - TeamViewer GmbH - C:\Program Files (x86)\TeamViewer\Version8\TeamViewer_Service.exe
O23 - Service: Intel(R) Turbo Boost Technology Monitor 2.0 (TurboBoost) - Intel(R) Corporation - C:\Program Files\Intel\TurboBoost\TurboBoost.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: Intel(R) Management and Security Application User Notification Service (UNS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: VideAceWindowsService - Unknown owner - C:\ExpressGateUtil\VAWinService.exe
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: vToolbarUpdater14.0.1 - Unknown owner - C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\14.0.1\ToolbarUpdater.exe
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\Windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
O23 - Service: Yahoo! Updater (YahooAUService) - Yahoo! Inc. - C:\Program Files (x86)\Yahoo!\SoftwareUpdate\YahooAUService.exe
O23 - Service: ZAtheros Bt&Wlan Coex Agent - Atheros - C:\Program Files (x86)\Bluetooth Suite\Ath_CoexAgent.exe
End of file - 17815 bytes
