tdcarter72
Sounds like you have a bad hard drive then. And I doubt you'll be able to repair it if issues happens once its attached to a system.
Thanks for the help!!!!
I do have a couple of questions regarding the seatools scan disk that I burned and what my next steps should be.
If I unplugged (power and data) cables on bad hard drive that was causing the read disk error message, why will my pc not run the seatools disk so I can check my other hard drive?
Can I download my OS to my other hard drive that I have been using as storage? If so, what steps should I take in preparing the hard drive since it was used as a storage device?
Do I need do anything is the bios since I am removing a hard drive?
