Hi Guys
Im new to this forum..so im popping over to say hello and seek a bit of advice
Can i directly transfer the contents of a laptop Sata hard drive to another new sata hard drive and then remove the first hard drive from the laptop- then fit the second one and then boot up and run the computer from the new hard drive....Im hoping the answer is yes
If so do i need to be concerned about formatting the new hard drive first before transferring everything over including the whole of windows if so what do i do about the boot sector which is usually formatted differently..i have only every laid a fresh copy of windows onto a computer.. so this way is new to me..my sons laptop is saying that the hard drive is damaged and may fail but every time i try to do a system image it fails to create and gives me an error message
i have checked the source and destination drives for errors which might cause the backup to fail but i unable find the cause..so i though that maybe i could just buy a new hard drive and then transfer everything across to a new hard drive and then simply use that hard drive to run the computer.
My other concern is that the hard drive in the Toshiba windows 7 laptop is quite small at 320 gig so i wondered if i could use a new 1TB sata hard drive as they can be had for around £50 on the internet but how would i easily utilize the other 680 gigs of space without first formatting the hard drive in order to create a partition for the extra space otherwise it will be unusable to me
Will Windows 7 recognize a 1TB hard drive ?
Thanks in advance for any assistance you may be able to offer
