^ Hahaha. Quuaaddd.Jamebonds1 said:Nice QQQQQQQUUUUUUUUUAAAAAAAADDDDDDDDDDDD set![]()
I think you mean (H80i) on the cooler.
H100i is 240 rad.
I like that Motherboard how it has a cover over it.
How much RAM is that? I only see 4 sticks in your sig.
Cable management could do with tidying up a bit, Fury (mind you, I can't talk about that though.) Otherwise looking good.
Not really too bothered at all by the cable management, but thanks for the suggestions for improvements.Meh, you could have done several things better for cable management.
Just a couple things to start, the USB header etc cables could have been ran along the back and zip tied instead of putting them to the front. Also, zip tie them all together to give a cleaner look.
The one fan you have running across the middle of the board looks like it could have went to the fan header at the top of the board beside the CPU fan.
The 4 pin CPU power cable can be zip tied with the bulk of the wires above and then shoot down to the board instead of just running across down low.
The 24 pin connector can be not put up in the 5.25 bays but rather ran down behind the 3.5'' bays and taken straight over instead.
On the CPU heatsink, the cleanest look is to leave the cable wrapped around the heatsink not to take it off and bunch it up. Swivel the heatsink around until it works out and then mount there.
This is a little crude but you get the idea.
Crappy picture, but you get the idea.
*snip*
The cables on the power supply are very long and the case is very small - that's why I just shoved it all up n the 5.25" bay. I really wish I had gone modular or semi-modular but I pressed the order button without thinking about that.
I forgot to mention about the cooler: I kind of messed it up when I installed it. I installed it, and somehow the fan was getting caught on the little wire, preventing the blades from spinning at all. I took the wire off the cooler itself and just had it hanging loose and then my fan was spinning again, so I just bunched it all up because I'm too lazy to take it all off.
