club 3d 7870 joker card.
hi turbo master i have purchased two of the club 3d joker xt 7870 card and having a little difficulty setting them up ( i am not very good on computers ) have you had any problems and is there any hints or tips you could give me. cheers phill.
no normaly its just put the bridge to both cards and look in youre driver if the are in crossfire should by an option there.
start gpu-z and look if the are in crossfire.
dont now what system you have buth did you turn youre onboard video of in the bios.
let my know if it worked.
and i want to now what the will do in 3d 11, pleasssseee post youre score.
1 card goes in the top pci-e slot
and the other in the second.
put them togeteher yusing the bridge.
open ccc configuratie centrum and look there if you see the option somwere enable crossfire after that you open gpu-z and look if you see 2 gpu,s.
dont forgett to instal AMD Catalyst Application Profiles. this is the download link for the windows 7 64 bit version.
if you run another os, then search for that http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_vista64.aspx
hope youre powersupply is enough
hi i have physically done the installing its the drivers that are giving me problems. when i pull up gpu-z it says there is a gpu card in but thats it no specs or anything .
plus ccc doesnt install so cant turn crossfire on or off.
my specs are
amd 6100 fx black edition 3,3 ghz
gigabyte motherboard think its 970 d3
antec modular 750 w power supply 2 X 7870 joker xt graphics card
western digital caviar blue 500 gb hd
hope this helps running windows 7 64
if power supply is not enough then i will just run one til i can source another one.
also i am a complet newbie when it comes to using the bios i have to get someone else to do that for me so i am not sure about onboard graphics issue.
thankyou for all your help phill.
do a clean instal of windows, and try the drivers again, the 750w psu is more then enough.
ore try first 1 card instal the drivers and put in the other 1.
turn of the system before you put in the other 1 haha.
if that wont work do a clean instal of windows 7
have done a clean install i think i am making a little headway as they are working now i have used the S.T.A.L.K.E.R call of prepyat benchmark and got over 300 fps on high
good for you, now i hope is see the scores from 3d mark 11, 3d vantage, and the new benchmark 3d mark.
i,m realy want to now the scores of 2 7870 xt in crossfire, because you cant find anything on google over 2 of those cards.
hi i dont know how to paste the pic but on 3d bechmark
overall score was 8856
graphics score was 12419
and hardware score only 4389
only runnin 6 gig of corsair dominator ram plus everything is on stock dont know if these scores are any good think my processor and ram let it down but played crysis two on full and played smooth hope this help .
plus for some reason cpu-z still wont recognise my graphics card it just says radeon 7800 but noe specs everything is blank so i am not sure if there both working correctly or not?
was that the score of 3d mark 11????
and you say here tha CPU-Z wont recognise youre card.
but try Gpu-z in stead.
but i find it a disapointing score so it seems that there is a bottleneck (cpu) ore somting is not good.
there shoot be 3 scores graphic score, physics score and a combined score
and why do you have 6 gigs of ram, you have a dualchannel bord so to get the best performens its better to fill all banks.
but as you will see in the pic cpu-z says nothing by me to.
look at Gpu-z on the bottom there it will say ati crossfire disabled ore 2 gpu,s.
i only have 6 gig of ram as this was from my last rig my 17 decided to evoerheat taking out mobo and prcessor but that is next on list plus maybe better processor thanks about tip on gpu-z
yes gpu-z saying crossfire is enabled so looks all good just gotmto upgrade system to catch up with graphics cards :)
good to here, and yes the next upgrade should by the prossesor i think, can you tell me what kind of system you have, mayby your motherbord is holding down youre prossesor.
and then i want to see scores please haha.
my system is as follows at moment i cant afford new mobo or processor yet as i only got these last week after my inel I7 920 decided to crash and burn (literally).
gigabyte 970 ds mother board
amd 6100 black edition 3.3ghz
6 gb corsair dominator gt ram 9,9,9,24
2 X club 3d 7870 joket xt
antec true power 750
caviar blue 500 gb hdd.
