That is a VERY low end board. If the OP is on a STRICT $60 budget, okay. But if you can spend more than that, do not get that board. B75 is not overclockable, so if he gets a i5 3570K, or i7 , he wont be able to OC. Also, it has one PCIe slot, so if he wants another GPU, nope, and if wants any PCI card, like a wifi card, raid card, etc., nope. Only has 2 Ram slots, also. So, get the UD3H if you can, best board in its price range. That is a VERY low end board. If the OP is on a STRICT $60 budget, okay. But if you can spend more than that, do not get that board. B75 is not overclockable, so if he gets a i5 3570K, or i7 -K model , he wont be able to OC. Also, it has one PCIe slot, so if he wants another GPU, nope, and if wants any PCI card, like a wifi card, raid card, etc., nope. Only has 2 Ram slots, also. So, get the UD3H ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813128544 ) if you can, best board in its price range. And Z77 is jot "too much", it is the best chipset out there, and isnt too expensive.
