Hi, I have tried googling this and there is info out there but my case is quite specific and it's hard to find an answer for it, yet I think a lot of people on this forum will know the answer.
Basically I got this computer from a friend who I unfortunately now don't really speak to and don't really wish to. At that time it came with XP which possibly was a Uni license (or something, I'm not 100% sure, I seem to remember this being mentioned but he might have been talking about the software instead, I forget).
I bought a Windows 7 upgrade and used it.
I'm bought a SSD and am planning on cloning to that but I'm just wondering if something goes wrong, or really just in general if/when my HDD or future SDD drive fails if I will be stuck.
I don't think I have the product key for the XP. I see there are software tools out there to find out the product key of the OS you're running, but will these just give me the results for my Windows 7 upgrade? :|
Also, if I do find out the XP key and put the OS on the SSD before wiping the HDD, will it activate again? I know you can't have the license in use on multiple computers at once but I'm not really sure how it knows whether it's in use, is it because I'll be using the same motherboard?
Finally, if this screws up, can I use my windows 7 activation on my ollllllddd xp computer or is it tied to this version of XP now?
Thanks for any help.
