internet problems
kapital
I have a problem with internet. When I try to open any page it shows it normally but I cant use for quite a lot of time(15-20s). It is the same with all internet pages. When I can use it it shows at the left upper cornes, like the page is still loading. Other things work the same as ussually, I already scan computer for viruses. Does anbody have idea what is this?
Unplug your modem and wait a minute and then plug it back it in and see if there is any difference.
Then it seems you have a problem with one of the addons for firefox. Adblock has caused problems loading pages on my end. I had to disable it for some webpages. Try it.
I do no thave Adblock. And I have the same problem for all wepages.
Sounds like Firefox is doing its usual thing of freezing up and going unresponsive when loading webpages.
I did not have such problems before. Why is it coming to this? Otherwise I can get all webpages, just with time delay.
What addons do you have installed?
2007 Microsoft office system, Adobe acrobat, Bio 3D, Cannon image gatway, chem draw, jva deployment toolkit, Java(TM) platform SE 6, Microsoft DRM, Shockwave flash, Shockwaveflash for director, Silver Plug-in, VLC Web plug in, Windows presentation fundation, Wofram mathematica
I have now tried Help --> Restart with addons disabled --> Star in save mode and the problem is fixed for as long as I do not exit firefox and open it again.
Sounds like you have an addon causing the issue. Start uninstalling/disabling until it works correctly.
