Go into File Explorer and right click on the PDF, choose Open With and then Choose Default Program. From here you will choose the program of your choice (Adobe Reader preferably) to open PDF and the OS will remember what to use from now on.
Also check to make sure you have a program installed that can read PDF files. Adobe Reader isn't installed as part of Windows and must be installed separately.
