Best Linux Distro for Live Tv streaming?
XBMC is its own Linux distro and is meant for media centers, so in essence it would be good for what you're looking for.
If you want xmbc, you can just install it from Linux Mint. You don't need to reinstall an entire OS. Run these commands in a terminal:
Code:
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install xbmc
Code:
sudo apt-get update
Thanks NyxCharon: i did in the terminal sudo add-apt-repository ppa:team-xbmc/ppahe
and it did not find anything.
What is the exact output?
You might be missing add-apt-repository, which can be fixed with:
sudo apt-get install python-software-properties
OK i was able to do it with, sudo apt-get install xbmc
it did load XBMC SOFTWARE ,now is anything i have to do to configure on the software manager for settings?
I'd assume all the settings for it could be set from a menu when you run it.
Thanks NyxCharon: i installed a few items from XMBC package but i don't think i need any of it, since i only watch soccer live events and already have VLC Player and Gerome Video Player as plug-ins and those are enough to watch live TV streaming,so i uninstalled the whole package
Me again One thing i don't like is when i go to these Soccer Live Tv sites they always say i need there plug-ins to be able to stream i have to go through some tedious X clicking to be able to watch games and when i hit those X exit buttons they present me with publicity crap that i have a hard time to exit out,why offer something that i don't need since 90% of the time my installed plug-ins work fine without their Adobe Hd flash players.
