mr.doom
So, after few months Western Digital bricked the access to my hdd with the new firmware update (MyBook Live). Issue is not new, but completely unresolved so far. I was told to RMA it back.
I could just do so, but I will loose all the data (a lot). Most of it are super important documents and pictures.
Before I send it I opened the casing, slotted the drive into an external enclosure and voil... wait a minute - it shows as RAW hard drive and it wants me to format it! I am running Windows 8 Pro 64-bit.
Question is: how can I convert the drive to NTFS? I tried the usual "convert" trick. It is not working. Alternatively, how do I access the hdd to get the data off of it and then I can format it in peace?
Thanks for the help, all I find on the net is from 2006 or earlier
