system:
C2D 3.16GHz
Gigabyte EP45-DS3R
6GB DDR2-800
EVGA GTX 680
Problem:
Ran fine for a long time on Windows 8 Pro. The other day I pull up Minecraft (which I'd done just fine the day before) and suddenly both screens are full of a colored pattern. The computer reboots, POSTs fine, and then does the same thing (though with a slightly different pattern/colors) before getting to windows. Reboot, go through diagnostics, it can't repair anything automatically, and I get the same pattern if I do safe mode, system restore, system refresh, or system reset.
Fresh install with reformat. Everything is going groovy. Get all my basic apps installed, then open a youtube video on Chrome. Plays for a couple seconds, then whammy, same issue, won't boot at all.
My first thought was a hardware issue. But then it shouldn't keep Windows from booting.
My second thought was a driver issue. But then it shouldn't reappear right after reinstalling Windows without installing the NVidia driver.
So, I'm down to it being an issue with the built-in windows driver and my card. But then why did it just now show itself? I had run windows update right before the first time it happened, but I purposely installed no updates before the second time it happened.
I've got a new card on the way (should be here tomorrow), but I have a feeling that won't fix it.
What am I missing?
C2D 3.16GHz
Gigabyte EP45-DS3R
6GB DDR2-800
EVGA GTX 680
Problem:
What am I missing?
