internet stalker
Lm90Rfgb
hi there is somebody has been following me on every online game i went. how could he possibly do that? i have an antivirus and firewall. but he still on every game i go.
What game is it? Team Fortress 2 automatically matches you to a server with people you have previously communicated with. I had this problem where every server I went on had the same two players, until I realised it was the same IP address.
hmmm, you say you have a firewall
a proper firewall or a built in one with cheap routers
the built in ones are ok for basic security i mean real basic but they are easy to get into because of the lack of features.
i think you should try and look at your firewall settings and change it around because sometimes by default certain ports and settings are enabled/disabled
e.g. some sky routers have remote acess enabled by default and some ports are open to the WWW
sir i dont have a router.. but i do have an antivirus that has firewall, zone alarm. dont you think its not enough?
because that person approaches my new character on beginners area say something awful things he/she knew about me when he/still hacked me long time ago. sometimes i feel that this person is not doing anything else than to guard those online game. he/she is so annoying.
I'm guessing either you have been infected with a keylogger or you have a friend that sees where you go online is causing you hassles.
You may want to scan your system for malware.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Vista and Windows 7 users must right click on the hijackthis icon and click on run as. If the run as option doesn't appear then press and hold the shift key while right clicking on the icon to get it to appear.
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
