Looking for a specific Graphics card
Freakyboy67
I am looking for a Graphics card which will work with my computer. I also have some money to upgrade the PSU if you can also find a compatible one that would be great.
Specs of Comp:
Hewlett-Packard Pavilion p6-2103w Desktop Computer Refurbished QW729AAR#ABA - Micro Center
Click "Specs" under the picture of the computer.
I have 150$ I want to get the best graphics card I can and get a PSU that will work with the card.
That PSU can not run a dedicated card of any strength. Really any card at all safely.
Aside from that, do you know what interface your board uses? Of the model of your motherboard?
Also what is the budget?
Simple google shows it has a 2.0 x16, and stock is a pentium g630, which is ok for gaming but not ideal.
If you want this for gaming, I'd aim for a HD7770 or 7790 depending on the budget, and a corsair cx500
All the gaming I want to do is Minecraft.... Which doesn't require a lot
That's the whole goal of the upgrade? Not worth it IMO, you'll end up spending like 100 just to play that game
I just want a smooth game, I was also looking into possibly doing a YouTube channel. So, if I could get 30-60 FPS recording it would be even better. :P
Corsair cx500 and a AMD hd7770 would be best if you would like to try some real games too and avoid upgrading again, but a 6570 should be plenty of power i guess
