I guess I'll go for 900$, but dang, 730$ build can't even run next-gen? How does PS4 manage when it's probably only going to be like 450-500$?
That would be very dumb, okedokey. Cheaping out on important stuff to get a 7950. Biostar is pretty bad, espieccally the low end stuff, which is trash. The HDD is bad, and I have never heard of the RAM or Case. I also imagine the CPU is a bottleneck to the GPU. Johnb35's new build is good except for the case. Get a NZXT or Corsair, like the Source 210 or 300D, and get windows 8.
Dude, that will be fine, and get himn 60FPS on any game at 1080p for 800/900 bucks. That was the breif.
The mobo is fine unless you wanna go SLI.
The 2500K will belt anything apart from the top of the top.
The PSU is fine, the ram has a warranty, and the hdd is perfectly fine.
The system i suggested for 900 will destroy almost any system on this forum with the 2500K at 4.7GHz.
I too would not use Biostar. For a matter of $5 more you can get a much higher quality ASrock (not the best brand, but fine for a low end unit). http://www.newegg.com/Product/Product.aspx?Item=N82E16813157315PS4 is coded to the metal. Doesn't have the API overhead that PCs need to be compatiable to many types of hardware.
For $800 you can get yourself a great computer that will play almost anything
MOBO - H61MLV2 (Biostar) - $45 http://www.newegg.com/Product/Product.aspx?Item=N82E16813138378
CPU - i3 2100 - $119 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
RAM - AVEXIR 8GB (2 x 4GB) - $53 http://www.newegg.com/Product/Product.aspx?Item=9SIA0ST08P6216
GPU - Gigabyte 7950 - $305 http://www.newegg.com/Product/Product.aspx?Item=N82E16814125414
PSU - TX650M PSU - $100 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139031
CASE - Chaser A31 case - $93 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811133212
WINDOWS - Home Premium 64 bit - $100 - http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
HDD - Toshiba 500GB - $60 - http://www.newegg.com/Product/Product.aspx?Item=N82E16822149435
DVD - Lite-on DVD Writer - $25 - http://www.newegg.com/Product/Product.aspx?Item=N82E16827106352
$800 including shipping etc.
If you can spend $900, spend the extra $100 on this 2500K instead of the 2100.
So $800 as above or $900 with a 2500K (which is still one of the fastest cpus)
Either system will destroy most games.
