Hey,
So lately (don't know why) I have been intrigued about Liquid Cooling. So I went on over to the How To:Liquid Cooling 101 thread and took a gander. Noticing that it's one hell of a well done thread, I decided I want to go for it.
Now right now I am just pricing everything that I want to do out to see if first I can afford it lol. I am more going for aesthetics more than function. I mean, I'll use the function no doubt, but not the main purpose.
Here's what I have found so far:
XSPC Raystorm CPU Water Block
XSPC Razer GTX680 GPU Water Block
FrozenQ Liquid Fusion V Series 250ML Res
Some 3/8" tubing
Black Compression Fittings
Some Sort Of Pump (undecided)
Several Questions, please answer as many as you can:
1)What is your opinions on what I am trying to do?
2)Should I go Clear or White Tubing? (I thought maybe White because of my 600T Case is white)
3)What brand of compression fittings would look pretty good, but won't make my wallet hurt?
4)I want that sort of Resevoir, but are there better brands or will I be ok with that brand?
5)In order to liquid cool a GTX680, does it matter which GTX680 I buy? (I obviously need to buy one cause all I have is a 660 and it's retarded to liquid that one).
6)The reason I haven't picked out a pump yet is because I don't know if I should show off the pump (get a pump that looks good) or somehow hide the sucker. Opinion?
7) This one is random: I also want to replace my PSU with one that is quieter and is individually sleeved, suggestions? Or should I just sleeve it myself?
I could really use the help if possible. Please answer by number. Hopefully someone can give me advice.
Thanks
Some 3/8" tubing
Thanks
