Thanks a lot Salvage!
Now I am just about completed my list of parts. I am actually comparing the cost between all barb fittings and all compression fittings, and in the grand scheme of things, it's not really that much more.
The question I have is "When shopping for a radiator, how does one know what brand to go with? or what special features you should look for?"
I want to get two dual 120mm radiators (For front and top) but no idea what i am looking for in a radiator. How does one out perform the other?
Side question - I have been watching a guys youtube channel
(here is his channel). This guy seems like he knows a little something, but one point he brought up was a change in manufacturing of tubing. I can't remember the exact video. But anyway, this guy explains that it is not actually the dye that clogs your loop, it's the deterioration of the tubing. He explains that the discoloration of the tubing is the deterioration actually happening.
I kind of believe this dude. I mean dye is just dye, it would make sense that the plastic tubing deteriorating would cause a clog/buildup not the dye. Now the dye could cause a faster deterioration than no dye.
Couple Questions:
1)Would you recommend using dye?
2)Has anyone notice that one brand of tubing deteriorates faster than another?
A tubing that I am specifically looking at is
"XSPC FLX Premium Grade PVC Tubing (3/8 x 5/8)" I was looking at Tygon, but can't find a white tubing. But if there is no problem using dye, I was going to go with clear Tygon with blue Mayhem dye.
