HDD Error...
clquestor
Hey guys,
Upon booting Win8 Pro my pc gives me an error that there is a hard disk error and I should backup everything. Clearly one of my hard drives is having issues. I have a 300g sata for primary and a 500g laptop drive with a 3.5" adapter for secondary storage. In disk management they both show up as healthy. Once I click cancel the pc runs fine but I don't want to risk everything.
1) Is is a C drive problem if that error shows up once windows load or is it just picking up that one of the drives has an issue?
2) Is there a way to determine which drive it is since disk management says both are healthy?
Thanks.
I would run a disk diagnostic on each drive to be sure. What you are getting is a smart error and needs to be figured out which drive is bad.
How would I go about running a diag on each? Is that bios or windows based? Or do I need another program?
I recommend the dos version providing you have a brand that supports it. What brand of hard drives are they?
