Shlouski
Hey Shlouski, what's the spec of the PC in that bottom pic?![]()
I think its a:
Striker ii formula
e8400
4gb ddr2 800mhz
9800gtx+
NOX 520W PSU
500gb HDD
I like how you just have a 'spare' Q6600, 16GB of RAM and 8800 GT lying around.
If I put together a machine made out spares it wouldn't be anywhere near as good as that.
No S***. You rekon? The issue is that more than a few of them carry EPS and P4 by default, meaning that no matter what system you have or what you use CPU wise, there is always a cable extra at a minimum. Full modular or don't bother with it, period.
if you say so, but the ones I have used had 2 CPU power (EPS and p4) and the 24 pin. Meaning they had 1 useless cable at a minimum.
To me the whole exercise is useless seeing as you don't save any money with semi modular, and full modular is cleaner, and without the useless cable.
Just because the ones you used did doesn't mean they are all like that and you can't make a blanket statement of just saying to skip ALL semi modular PSU's. A semi modular that just has a 24 pin, a 4+4 pin EPS, and perhaps even a PCIe cable non modular will be no less clean of an install than a fully modular PSU, and the semi will be much cheaper.
The CX600m is only $60 after MIR right now, an amazing deal. Find a fully modular PSU of equal strength and quality and you're looking at $100 atleast, with much more limited choices as well. Newegg has 58 fully modular PSU's, and 161 semi modular currently.
Jamebonds, those are the cables, and could be attatched (or come with in modulaur) with/on any PSU, modualuar or not.
