Gaming PC for £550
Kornowski
My friend is looking for a gaming PC with about £550 to spend (just the tower and OS). I've been out of it for too long to really know what's good any more, so what would people suggest?
Must be a pre-built, so can't buy the parts individually and build it for him.
Thanks for any suggestions!
If it needs to be pre-built something like this would probably be good http://www.novatech.co.uk/pc/range/novatechblacknta12.html I've used some of Novatech's pre-built desktops before and they've all been pretty good. The FX-6300 and 7770 will be fine for gaming. Just be aware that if you need an OS installed on it, the price jumps to over £600.
Note though the case and PSU won't be the best, but that's the price you pay for buying pre-built. Everything else should be fine.
I was looking at that, seems a good price, but he needs the OS, too.
How about this?
http://www.ebuyer.com/492089-cyberpower-gaming-squadron-gt-ecc01152
Sorry didn't see the link you posted in the last post. Yep that's pretty decent, but just be aware of the power supply (it'll probably be OK though). I'd say the one you found on eBuyer is probably better than the Overclockers one.
