Need Help - $800 Build
Lgbenr
Hello, I am building a full computer, and my budget is $800 which includes monitor, keyboard, mouse, and operating system. I would like to have all the parts from Newegg. Any help in making the build list would be greatly appreciated.
Ben
These guys can help you pick the parts but is there a reason you want Win7 over Win8? Win8 will be easier for you to get and runs MUCH better than Win7. If you are trying to avoid the changes don't bother...you get used to it very quickly.
I don't see the point of changing what's not broken.
Edit: I am not necessarily stubborn, I actually do not know much about windows 8 besides what I have experienced on the mobile interface. If it is that much better then I will definitely take that option into account.
Correct its not broken, but Win8 runs noticably better. If you took a 3 year old machine, Win8 would run better than Win7. Its a lighter yet more powerful OS. I'm sure the experts here can better explain why that is. But overall its everyones opinion and in the end, its your new pc so get what you think you'll enjoy the most.
I've used both and I feel that 8 is basically a faster and smoother version of 7. A lot of the underlying fuctions (think Control Panel) is primarily the same. The mobile interface is there if you want but you can use it just like 7 in terms of the standard desktop. And if you really miss the start button you can find an app to get that back.
Just keep in mind if you have old software it might not work as well on 8 as 7.
7 is still awesome, but 8 is probably a better choice. Everyone has their opinions though and people will say one is better than the other for a variety of reasons. I feel a flame war a brewin'.
Anyway for parts I don't have time to get you a list but I'd guess you'll be in the neighborhood of a FX 6300 and a Radeon 7770 or so for the CPU and GPU. Others here are better at builds than I but that gives you a place to start looking for yourself.
Here is the list I come up with...
$823, MIR $20, exclude shipping and tax.
i5 3350P
GIGABYTE GA-Z77-HD4
Team Xtreem LV 2 x 4GB DDR3 2400 TXD38G2400HC10QDC01
Western Digital WD Blue WD10EZEX 1TB
ASUS HD7790-DC2OC-1GD5
LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
CORSAIR CX500M
CORSAIR 200R
Windows 8 OEM
Gift
Rosewill RNX-N150PCe wireless card when purchase WD Blue WD10EZEX 1TB
AMD Gift FARCRY3 Blood Dragon BIOSHOCK
i5 3350P
GIGABYTE GA-Z77-HD4
CORSAIR CX500M
CORSAIR 200R
Windows 8 OEM
Gift
The budget needs to include a display monitor as well, and I am not sure if a full 1TB will be needed. Any way you could fit that in?
Besides windows, 7 or 8 will be fine. Both are good Os. I prefer 7 myself. What are you planing to do with the computer, gaming? Just saying for 800 including a monitor/ keyboard, mouse and OS. Could probably do a better AMD build.
Gaming will be included, but nothing absolutely hardcore. It's basically an all around computer for every day use. And yes, if you could include the monitor, keyboard, mouse, and OS in the $800 budget that would be great.
NZXT Gamma case, WD 500 GB HD, Acer 20" monitor,Asus M5A97 LE AM3+ Motherboard, Corsair CX600M PSU, Rosewill 101 keyboard, Logitech wireless mouse, G. Skill 4GB 2x2 DDR3 1600 memory,FX 6300-vishera 3.5 GHz, Win 7 OEM(or win 8), and Sapphire 7770 1 GB GPU w/far cry and Far Cry Blood Dragon----789.89 before shipping and $35. in MIR.
I have thrown together what I think is a very good build, that puts the final price at about $831. If anyone could take a look at it and give me feedback, I would greatly appreciate it! :)
Case - COOLER MASTER HAF 912 RC-912-KKN1 $60
MB - ECS A75F2-A2(1.0) FM2 AMD A75 (Hudson D3) $60
CPU - AMD FX-4100 Zambezi 3.6GHz (3.8GHz Turbo) $105
GPU - SAPPHIRE 100358L Radeon HD 7770 GHz Edition 1GB $115
HDD - Western Digital WD Blue 500GB $60
Memory - G.SKILL Ripjaws Series 8GB (2 x 4GB) 1600 $63
PSU - CORSAIR CX600M 600W $80
Lite-On DVD Burner $18
OS - Windows 7 Home Premium OEM $100
Display - Acer G246HLAbd Black 24" $140
Keyboard & Mouse Combo - Logitech Wireless Combo MK260 $30
There were two G.SKILL 2 x 4GB listed at about the same price and they physically looked different but I didn't know what the difference was. Any help there?
Thanks
Sorry, I mis-read previously.
1TB is $75, 500GB is $60. For $15 difference, better off to 1TB
You could probably find some cheap monitor at $120 - 130.
Option 1
CPU - FX 4300
Mobo - MSI 970A-G46
RAM - G.SKILL F3-14900CL9D-8GBSR
GPU - SAPPHIRE 100358L 7770
Other stay the same. It end up around $690 for tower before MIR.
Option 2
CPU - i3 3220
Mobo - ASRock Z77M
RAM - G.SKILL F3-14900CL10S-8GBXL
This end up $700 for the tower.
Thanks
FX-4300 is a later CPU
MB - won't fit. You need to have AM3+ socket. And don't get ECS
Not a great build for the reasons outlined by Daisy above.
Option 1
CPU - FX 4300
Mobo - MSI 970A-G46
Option 2
CPU - i3 3220
Mobo - ASRock Z77M
Both are good but I'd probably take option 2 myself, but not with that Micro ATX ASRock board (unless you need a micro ATX case?) I'd get a board like this instead http://www.newegg.com/Product/Product.aspx?Item=N82E16813130653
Okay I went with daisy's build and with option two, but with the mobo you suggested, and with everything else that puts me at $885.89, which is still $86 over budget.. Could you try to get me down near $800?
