DDR2 Ram stick not working
Calin
Well-Known Member
For some reason, my PC will now post with that stick, no matter in what slot it is put in.
I tried all I know so far but it doesn't work
If it is your system in your Siggy, then try returning the CPU to stock and then try the stick. Assuming you are running 3.6GHz (20% OC), then you are hitting near to 1600 FSB, and the memory might not be able to keep up.
I tried.
Still not working.
