4RealzDiego
Im looking for a $1000 build for high end gaming...
I need this build fast.... Need the best rig you can get <3
I don't if GTX or AMD
Do you need a monitor and any peripherals or just the machine itself?
This one is a little bit over. Let me know if you need it cheaper.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=27474707
Not positive but you could save a bit of cash and get a Seagate Barrucuda HDD rather than WD and it's probably about the same speed.
Good build but get a Gigabyte UD3H Z77 and a TX 650M.
Well, quality control and support and RMA quality has gone way down with their motherboards over the years. Stick with Gigabyte and MSI.
I don't know much about motherboards. What makes that one better?
