burnm3w1thf1r3
I have a Geforce 9800 GT 1gb video card that I purchased off ebay. The seller stated that he couldn't get the fan to always spin up, which is why I bought it. Seemed like an easy fix, which has been fixed. However the card will lock up during game play at any temperature. Its done it at 56c, 65c, 68c etc. I know it is not an overheating issue because when it does over heat I lose the signal from the card to the monitor (the monitor acts as if the pc was in standby or sleep mode but won't wake up). Upon one of the times that I dismantled the card and reassembled it the lock ups were minimal, unfortunately I didn't have the correct grease so the fan was having trouble spinning up but would only lock up very rarely. Today I dismantled it to fix the fan and upon putting it back together the card now locks up very often still at low temperatures.
There is no error code just the PC will lock up for a few seconds to roughly a minute but after that the pc will free up and the graphics of whatever game was running are distorted to which either a minimize and restore will correct or a close and reopen. Even though that fixes the picture it locks up again after a few minutes.
I have absolutely no idea what was different from the time before i touched it (locking up) to after I fixed it (still locked up), to refixing it but using the wrong grease (worked much better, very minimal lock ups), to now fixing the fan (very often lock ups).
I did however get an error ONCE while running Windows 7, however the picture was so distorted I could not make out what it said and I have not been able to replicated it since.
Any ideas on how I can salvage this video card? Or is there a program that will monitor processes of the video card and report when it faults almost like "WhoCrashed" with windows BSODs.
Specs:
BIOSTAR T-SERIES TA690G AM2
AMD Athlon 64 x2 Dual Core 6000+ 3000Mhz
4 GB GSkill 800 Mhz DDR2
Nvidia GeForce 9800GT 1GB
Screen captures or CPUID:
Specs:
