Does Memtest86 give false errors?
When my OCZ power supply unit went I could smell it smoldering. It did not have the violent death that I saw in a garbage "Bestec" brand power supply. That power supply made a loud violent sound and then it smoldered as well.
Is it correct then to say the hardware has suffered two PSUs failing?
Id say most the time it does damage stuff. When they go, they let rip.
Well I dont buy cheap supplies, so most of the failures havent done damage. Where as cheap supplies are bad of having voltage spikes/burn outs. Which does cause problems.
Is it correct then to say the hardware has suffered two Power Supply Units failing?
No, that Bestec power supply was in a computer I was working on for someone else. It was an original equipment manufacturer computer that had it. I would not put one of those junk power supplies in any of my systems.
