Gaming Pc
John Locke
I know that there are many posts about this but not a single one of them gets to my expectations.
I have around 800-900usd as my budget.I really need some help because I need to order the parts this week.
Just post like you were making your computer with 900 usd.
:D thanks
Well if its a flat screen it's probobly okay, no CRTs though. Oh, and I am Desmond Hume, brotha ;)
Gigabyte UD3H Z77
i5 3570K
HD 7870
Seagate Barracuda 1 Tb
G.Skill 2 x 4 GB 1600 MHz
Corsair CX500M
Corsair 300R
Logitech G9X and Sidewinder X4 or Steelseries G6V2 for phierpherals
Will be around $900 or less
One more thing Desmond, if you were in europe where would you order everything?
And do you think that I should get a free version of windows 7 or buy it?..
Free version of windows 7? And I would get windows 8. Novatech and overclockers.co.uk are good places to buy stuff.
Dude do you think that if I order from neweg will there be any problem?
Because the shipping is free and on the uk ones when I put pounds to euros it goes over the neweg total price..
Ahh... no, I wouldn't. For $100 you get a OS you never have to worry about or anything. Especially when you are already spending $900, and as is said get windows 8. And newegg doesn't ship to Europe.
Depends where in Europe you are. If in the UK, I recommend Novatech personally, since that's where I buy my stuff from. Overclockers is also good.
And since discussing the use of pirated software is against the forum rules, I would stop going on about pirating 7.
Im in Portugal so I think there is no online shop to do that on this side..
Spirit, I've checked those uk sites but after the total it comes up to my expectations. If you know any site that is more cheaper or more inside europe, be my guest
Sorry for the Windows 7 issue Im gonna stay true to it and buy the os..
Unicorn os spirit do you think that with that new parts Im gonna be able to play Arma 3 Battlefield and etc... with good fps and good quality?
By the way unicorn one of my iraqi friends told me that the nvidia inno3d I dont really now whats the difference but.. what do you thing?
Gigabyte UD3H Z77
i5 3570K
HD 7870
Corsair CX500M
Corsair 300R
Just get the stuff in the build above, however I'd get a 600W or 650W PSU for a 7870. 500W is cutting it a bit short for a 7870, and it's always good to have some headroom.
Here are the parts on Novatech:
UP4-TH: http://www.novatech.co.uk/products/...5z77chipset/atxformfactor/ga-z77x-up4-th.html (since Novatech don't seem to stock the UD3H).
3570K: http://www.novatech.co.uk/products/...ncorei3,i5andi71155socket/bx80637i53570k.html
Hard drive: http://www.novatech.co.uk/products/components/harddrives-internal/sata1tbto1.5tb/st1000dm003.html
HD 7870: http://www.novatech.co.uk/products/...aphicscards/amdhd7870series/fx-787a-cnfc.html
RAM: http://www.novatech.co.uk/products/...dr3-pc3-12800/1600mhz/f3-12800cl9d-8gbxl.html
Corsair 300R: http://www.novatech.co.uk/products/components/cases/cc-9011014-ww.html
Power supply: http://www.novatech.co.uk/products/components/powersupplies/cp-9020060-uk.html
That's £736.88 for the components (excluding your OS and your perpiherals).
Windows 7 Home x64: http://www.novatech.co.uk/products/software/operatingsystems/gfc-02050.html
Or if you'd prefer Windows 8 Pro x64 you can buy it from here http://www.novatech.co.uk/products/software/operatingsystems/fqc-05955.html
I've used both 7 and 8 a lot and both are great operating systems. Whichever you pick you will be happy with I think. For Windows 7, Home Premium is enough so long as you don't plan on going over 16GB of RAM, but for Windows 8 I'd always recommend Pro.
If you want my suggestion for a mouse, then the Logitech G400 and G500 are great mice and are affordable. I've been using my G400 for over a year and it's a great mouse. The G500 has removable weights and is not much more expensive http://www.novatech.co.uk/products/peripherals/miceandtrackballs/gaming/910-001262.html I would personally stick to wired mice and keyboards over wireless because you don't have to rely on batteries and they respond a bit faster.
I don't really know a lot about keyboards but I'll go with the keyboard PCunicorn recommend: the Sidewinder X4 http://www.novatech.co.uk/products/peripherals/keyboards/gaming/jqd-00006.html
If you're not in the UK, then Novatech do ship to other European countries. See information on this here http://www.novatech.co.uk/deliveryeurope.html
Hopefully this all helps. :)
Sorry Okedokey.
And thanks Spirit and PcUnicorn I've been talking with my friends and the said that is really good :D thanks.
Now time to order thanks :cool:
Still it goes over the 1000 euros..
Spirit where could I cut the cashinga? ( If I can whitout taking the good of the super pc..)
Im gathering more money but I dont think Ill be able to get it.. 736 pounds - euros it goes over 850.. and plus the os,keyboard,mice it gets to 1000 euros..
I dont know how this failed me but there is still missing the dvd part.. xD
Spirit you think I could install windows using usb?
