Jonah
So in January i built myself a new pc to replace my windows XP netbook. It was running fine until yesterday, May 13, when i got a message from windows asking me to print instructions for backing up my "failing" Hard drive. I downloaded HDTune and found out i had 530 Bad sectors. I don't have a clue what this means, and when i Googled it i found that most people had 3-10 bad sectors. I set up windows backup to backup onto a supposedly 80gb external HDD. Software and hardware again not agreeing what a gigabyte is, it turned out it was only 55gb, the same as the used space on my PC. I tried to backup anyway but it was taking hours so i cancelled and shutdown.
Today i tried to boot up to find my BIOS saying that my HDD is failed and it will not boot anymore. I booted up a spare copy of Linux Mint i had lying around on a DVD and started copying my files onto my tiny 4gb USB drive. I thenn took the drive out, put it in an external enclosure and plugged into my netbook. I now cannot open the disk in explorer and it refers to the drive as "local disk" not J-PC like the drive is called and linux called it. It seems the drive is in 2 partitions, and the tiny "system reserved" one opens fine, but only has some microsoft stuff in. I'm now running my tiny netbook again, and it feels so slow and bad.
The HDD is a cheap WD Scorpio black i bought from amazon along with the rest of my build.
So my questions are:
1-What is a bad (reallocated) sector?
2-Is this affected by software and what i was doing on my PC yesterday?
3-If I buy a 128gb SSD, will i be able to clone my disk onto it or is it already too corrupted?
4-How would i clone it?
5-If it is corrupted, will i be able to install to the new disk from an OEM copy of windows or will i have to buy a user copy.
Thanks in advance, Jonah.
PC details
Asus M5A97 LE R2.0 Board
Cooler master elite 500w PSU
AMD FX6100 6-Core CPU
WD Scorpio Black 2.5" 160GB HDD
ATI Radeon 5450 GPU
Corsair Vengeance 1600mhz 4gb single stick RAM
Also, I'm new to this place and if this thread is in the wrong place, sorry :l
Update:
I booted linux from the DVD and could acces my files again. However i still can't install linux to anything to be able to clone the disk.
PC details
ATI Radeon 5450 GPU
Update:
