Please help!
snishsnawh
Hey everyone,
My computers recently become extremely slow.
I have ran a full disk de-fragment and done a full computer virus scan using AVG 2012 full.
I dont know why my computer is running slow.
I have been looking for ways to fix this but havent found any that have helped.
I thought that maybe a registry repairer might work.
Could anyone recommend me one?
Or ways to repair my compter
its not that everything is fine its just that it takes forever to boot up and randomly laggs when i open up something or click on something.
It took me 10 minutes to open up a website
While I am no expert, I'd say that sounds like a CPU filled with dust or it broken, or an HDD that is slowly dying.
What are your PC specs?
Download and run Ccleaner.
http://www.filehippo.com/download_ccleaner/
Click up top right where it says download latest version. After installation, open the program and click on run cleaner.
Then do the following.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Vista and Windows 7 users must right click on the hijackthis icon and click on run as. If the run as option doesn't appear then press and hold the shift key while right clicking on the icon to get it to appear.
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Check CPU temperatures and check if the hard disk drive is "BUSY" as it is reading/writing something (usually red led light) the WHOLE time for no reason.
Have you used msconfig to disable startup programs and services?
If not, here's what I do every few months..
Open msconfig.exe
Click Services tab
Click Enable All button
Click Hide all microsoft services checkbox
Click Disable All button
Click Startup tab
Click Disable All
Click Ok
Then restart your computer. You can go back into msconfig and re-enable programs and services one by one until you find what's causing the issue.
goto the security section and follow the instructions there then post the txt and wait for JohnB to reply.
