voyagerfan99,
Hello, good to see you again
Under the control panel I set the power options to show the battery icon in the taskbar when "active".
Therefore, if, for example, I were to start my computer up with the power supply plug in, which would be running off of the rechargeable battery that I have in the laptop, then a battery icon would show up in the taskbar.
And I know this because I have tested this principle -- in that I have done this exact thing before.
And sure enough, when started without the power supply plugged in, the battery icon shows up on the screen.
Also, when I start the computer WITH the power supply, and then "unplug" it after it is booted, the battery icon will show up.
The point that I'm trying to make is that my rechargeable battery will last for at least 30 minutes before running OUT of battery power, and thus causing an automatic shutdown.
However, during none of the times just before the computer went off, was there a battery icon on the taskbar.
And I wouldn't exactly say that 55 degrees is overheating, nor a cause for alarm
I have never heard of a video card overheating.
But I have heard of a motherboard overheating.
If, for example, I were to install the W2000 video driver, which I did, would that mean that since it wasn't the XP OS for which it was made, that it would reduce this driver to the statis of ineffective, as if no video driver had been installed at all, and that it would still be functioning under the format of "software renderer", as opposed to Radeon 9000 3D card render?
In conclusion, would it help at all, or would it be completely ineffective?
Okedokey,
Hello there. Glad you made it.
Haven't heard from you for a while!
No. You have never looked at this PSU.
It is a different computer/laptop altogether.
My other laptop died horribly, and most tragically.
I am still in mourning over it.
The specs of this computer: (posted earlier in this thread for the model type -- different than the Compaq Evo)
Model:
Dell Inspirion 5000e
Motherboard:
Compal Electronics, Inc. 440BX Desktop Reference Platform
CPU:
Intel Pentium III E
Coppermine 0.18um Technology
Captain Kirk
