Captain Kirk
Hey Spirit,
Thanks for the reply.
Yea, that's 'exactly' what I had thought at first too! It was then that I could no longer run any programs on the hard drive. It was worse than bad sectors. At least with bad sectors, you can still use 'some' of the data, but with this HD, I couldn't use ANY of it: I couldn't install any programs on it.
It was then that I scrapped this HD -- that is why I now have a different one in the computer now!!
So spirit, let's just say for a moment that you are right -- what are the symptoms that would appear from a bad HD? What about from bad sectors?
voyagerfan99,
good to hear from you.
voyagerfan99,
Thanks for the info -- that's good to know. Though I knew that XP's day were numbered. And in this case, literally. In fact, this is such an exact calculation that it has to be true. Well, at least XP still has another year. You know, Vista and W7/8 are such memory hogs, its really a shame you know.
Maybe your right, there is the possiblity that overheating IS an issue.
Yesterday, my computer turned off by itself 4 times.
I have had no blue screens at all for some time.
I considered your possiblility and so I tested it:
As soon as my computer shut off, I turned it back on and checked the temp --
It read 38 degrees.
But I heard that the overheating temperature degree is based on the CPU chip that is in the computer.
Could it be that finding out the name of this could determine what the temperature range for this is?
So what do you think it is -- the video card, or the board?
Captain Kirk
USS Enterprise
voyagerfan99,
voyagerfan99,
XP isn;t supported in another 413 days.
It read 38 degrees.
Captain Kirk
USS Enterprise
