So I just got a new Alienware computer after my last one had so many problems that they had to replace it. It had something wrong with it that made the graphics cards keep breaking. Twice they overheated too much and twice the fans started clicking. Then there was some other problem with the power button and to find that problem, they replaced the motherboard, media panel, and front panel. They also replaced the cooling system and the hard drive at some point. So my first question is, how would I go about fixing this problem? The only thing that hasn't been replaced on the computer is the power supply. It has 16GB of ram and a I7 processor so it would be a good server if I can get it fixed. Then my second question is how would I go about setting it up as a server. I understand that if I can get a second 1 TB hard drive I can have 1 TB of space backed up through some sort of RAID configuration. I can do that easily with Ubunux I believe. Then I would need help configuring Ubunux. But first lets focus on fixing the computer. Thanks.
