Post A Pic Of Your Pc Here :)
Your only changing part in years seems to be the SSD :P
Well hang on in the past 18 months I've gotten a new CPU, cooler, two new motherboards, three new SSDs, RAM, power supply and a new graphics card... not enough new parts?
More Core 2 Quadness for good measure. :P
That's about all the pics I've got.
Quad SLI and CPU on dry ice. This was before I got the benching station.
5770 with an 8800gts for PhysX :D
Back when I was into folding, gtx 275 co-op and another gts 250. All 3 GPU's folding, good points at the time.
9800GX2 with an 8800gts 512mb for PhysX. along with a *slight* cpu cooler upgrade :P
Don't mind the cable management. Case was crap for it, but I also wasn't nearly as concerned then as I am today with cables.
All top hardware at the time- I5 750 at 4.2ghz, gtx 285, 2x2gb G.Skill trident DDR3-2000, and 3x ocz vertex in raid 0.
4870 xfire setup-
Again, I know cable management not that great 3-4 years ago :P
So how about a newer build to show my improvement on that :D
I think it's time that I finally say:
Main UAC data complex center working environment room stage 2 is completely finished!!!
Stage 1 was finished on:
Time: 23:20 :)
Date: 29.03.2013. :)
Stage 2 is now finally completely finished on:
Time: 23:42 :):):)
Date: 02.07.2013. :):):)
So as you can see I just finished stage 2 about an hour ago as I am writing this.The feeling was SOOOO DAMN GREAT!!!!!!!!
From tomorrow I am starting with the LAST stage 3 which should not take me more than 7 to 10 days.
And finally after those 7 to 10 days,all 3 UAC stages will be completely finished and I will finally record a nice music video and show you my ENTIRE SETUP!!!
:D:D:D
Time: 23:20 :)
Time: 23:42 :):):)
:D:D:D
You should post picture :D
First time doing this :)
I'll add a second rad and a res when I have more money lol GO H220! I'm not doing crazy overclocks so temps are fine. I hated the stock cooler on the XFX 7950, the thing sucked.
Wow, nice adaptation to the stock setup, honestly if the temps arent crazy out of control id just maybe change fans and let er run. thats a clean setup...i like it.
gpu's been staying around 44-45C vs 70+ so good enough lol. Haven't really tested the CPU but i really don't max it out when playing games.
