DeltaDart1
New laptop with Windows 8. Trying to figure out how to disable the need to enter password every time to login. Went to youtube and followed a couple of the videos and neither procedures have worked. Both say go to run and type in netplwiz. Go to pc settings then click user.
Everything is going smooth. Uncheck the box that it says to uncheck,restart computer and still the computer needs you to login with your password. I follow the exact directions and still it needs a password to login.
Really is Windows 8 this dang difficult to figure something as simple as this? Are the videos on youtube just plain wrong? All I can do is follow what they say. Any of you run across this situation and what is the fix? I'm lost. Thanks!
