Da Mail Man
Greetings all,
Running a Dell GX280, 3.4ghz, (not the steam-lined one but the typical large desktop model) plenty of hd space and ram, win xp pro...
.....I have a fan problem, This fan is a large one mounted to the case with an internal fan shroud that directs the air flow over the heat sink. The heat sink is MASSIVE with 6 copper cooling tubes running through the fins of the heat sink.
....The issue is that the fan speeds up like an F-18 fighter jet. Physical exam of the processor and heat sink found no problems or defects. I have removed all the heat sink compound, applied new, and reseated heat sink and made sure the fan plug which plugs into the MB is clean and secure. I am fully aware that with heavy use, the fan may speed up a bit but, not like a rail dragster when slight to moderate use is applied.
**ADDITIONAL: The is not setting or adjustment in the bios for the fan(s)
....My research pretty much leads me no farther ahead then when i started in that, alleged findings have said:
1) that it is a faulty fan,
2) loose processor, (NA)
3) older style heat sink with just 2 cooling tubes (which have been "recalled or "discontinued"), (NA)
4) bad mother board. (DON'T THINK IT APPLIES)
...I have used a program called Speedfan but, found it to be junk - conflicting with my computer system. I have also used a program called 18kfangui which was also conflicting with same.
*************VOID BELOW THIS LINE**********************
...I thought at one point that the bios could possibly become corrupted so, I went to the dell site and downloaded the most recent bios which happens to be the same as what is currently present.
....taking an empty flash drive, I copied the bios from the dell site to the flash drive and made sure that the 1st boot device was the usb flash device. Shutting the computer down and plugging in the flash drive and turning it on, i get a drive error as to if it cannot find the flash drive at all.
...Here is where i am at present. Having flashed bios' in the past, this has worked however, i am not sure if the bios program copied from dell (.exe) needs to be clicked on in the flash drive to open it prior to booting into it.
**********VOID ABOVE THIS LINE**************
...So, anyone have any idea as to the fan speed problem?...THANKS.
		 ok.
 ok.
