I have a problem with my desktop.
Ok. Lets try something different. Boot to safe mode. Assuming this is XP. Click on start, click on run, type msconfig, click ok. When the system configuration utility pops up, click on the startup tab and uncheck all entries in the box and click on apply, then ok. Then restart in regular mode and see if issue persists.
When i was reading your reply, my desktop was already on Safe Mode with Networking. i didn't turn off the desktop yet, but read your replay and did the steps while still in Safe Mode with Networking. I restarted like i do normally, by just turning off and turning back on, but it hasn't helped. My desktop froze twice before i turned on through Safe Mode with Networking.
To make sure i did everything right, i double checked the stuff you told me to uncheck, at the moment, the stuff is still unchecked.
Run both of these in safe mode with networking.
1.
Please download and run TDSSkiller
When the program opens, click on the start scan button.
TDSSKiller will now scan your computer for the TDSS infection. When the scan has finished it will display a result screen stating whether or not the infection was found on your computer. If it was found it will display a screen similar to the one below.
To remove the infections simply click on the Continue button and TDSSKiller will attempt to clean them or remove them.
After trying to clean them it will pop up with the results of the scan and its actions.
Please reboot the system if asked to do so.
After running there will be a log that will be located at the root of your c:\ drive labeled tdsskiller with a series of numbers after it example, C:\TDSSKiller.2.4.7_23.07.2010_15.31.43_log.txt
Please open the log and copy and paste it back here.
2.
Download and Run ComboFix
If you already have Combofix, please delete this copy and download it again as it's being updated regularly.
  • Download this file here :
    Combofix
  • When the page loads click on the blue combofix download link next to the BleepingComputer Mirror.
  • Save the file to your windows desktop. The combofix icon will look like this when it has downloaded to your desktop.
  • We are almost ready to start ComboFix, but before we do so, we need to take some preventative measures so that there are no conflicts with other programs when running ComboFix. At this point you should do the following:
  • Close all open Windows including this one.
  • Close or disable all running Antivirus, Antispyware, and Firewall programs as they may interfere with the proper running of ComboFix. Instructions on disabling these type of programs can be found here.
    Once these two steps have been completed, double-click on the ComboFix icon found on your desktop. Please note, that once you start ComboFix you should not click anywhere on the ComboFix window as it can cause the program to stall. In fact, when ComboFix is running, do not touch your computer at all. The scan could take a while, so please be patient.
  • Please click on I agree on the disclaimer window.
  • ComboFix will now install itself on to your computer. When it is done, a blue screen will appear as shown below.
  • ComboFix is now preparing to run. When it has finished ComboFix will automatically attempt to create a System Restore point so that if any problems occur while using the program you can restore back to your previous configuration. When ComboFix has finished creating the restore point, it will then backup your Windows Registry as shown in the image below.
  • Once the Windows Registry has finished being backed up, ComboFix will attempt to detect if you have the Windows Recovery Console installed. If you already have it installed, you can skip to this section and continue reading. Otherwise you will see the following message as shown below:
  • At the above message box, please click on the Yes button in order for ComboFix to continue. Please follow the steps and instructions given by ComboFix in order to finish the installation of the Recovery Console.
  • Please click on yes in the next window to continue scanning for malware.
  • ComboFix will now disconnect your computer from the Internet, so do not be surprised or concerned if you receive any warnings stating that you are no longer on the Internet. When ComboFix has finished it will automatically restore your Internet connection.
  • ComboFix will now start scanning your computer for known infections. This procedure can take some time, so please be patient.
  • While the program is scanning your computer, it will change your clock format, so do not be concerned when you see this happen. When ComboFix is finished it will restore your clock settings to their previous settings. You will also see the text in the ComboFix window being updated as it goes through the various stages of its scan. An example of this can be seen below.
  • When ComboFix has finished running, you will see a screen stating that it is preparing the log report.
  • This can take a while, so please be patient. If you see your Windows desktop disappear, do not worry. This is normal and ComboFix will restore your desktop before it is finished. Eventually you will see a new screen that states the program is almost finished and telling you the programs log file, or report, will be located at C:\ComboFix.txt.
  • When ComboFix has finished, it will automatically close the program and change your clock back to its original format. It will then display the log file automatically for you.
  • Now you just click on the edit menu and click on select all, then click on the edit menu again and click on copy. Then come to the forum in your reply and right click on your mouse and click on paste.
If for some reason, if you try to run a program or open a file and you get an error message saying "illegal operation attempted on a registry key that has been marked for deletion", please just reboot your pc and you'll be fine.
In your next reply please post:
  • The ComboFix log
  • An update on how your computer is running
If this doesn't solve your issue, I would recommend reinstalling windows.
For some reason, i cannot download the file to desktop because i can only use Mozilla Firefox, not Internet Explorer or Chrome. Another problem is i can see the Combofix.exe in my Downloads folder, but i can't move it to the desktop, because the computer won't let me. What if i just run the file? Is that OK?
I ran the EDSSKiller program after downloading it, no viruses came up.
I'm having problems disabling the antivirus programs to have Combofix have no problems, it's sort of a headache. i was thinking about just uninstalling the antivirus programs instead, is that OK?
Because sometimes its required to run a special combofix script to delete malware that combofix doesn't get.
And you can always change the location where your downloads go. When you get the download box, on the bottom left corner you will see where it says browse folders. Click that and navigate to where you want to save it to.
But does Combofix have to be downloaded onto the Desktop? And, I don't have a printer with me, so i am thinking about stopping by the library to print out the directions to how to run Combofix. Is that necessary? Because in the instructions, it says to cancel out all the windows that are out while it's installing, so i can't view the instructions while it is installing. (or something like that) I find it hard to memorize stuff.
You shouldn't have any open windows when running it. Basically all you have to do is disable your antivirus or uninstall it temporarily before running combofix. Pretty simple instructions.
You mean all i have do is uninstall or disable the antivirus programs i have, then just use common sense to install combofix? For the antivirus programs, i don't remember all the ones i installed, there is the chance i try to uninstall all my antivirus programs, and maybe miss one and then try to install combofix. Is there a way to 100% be sure that i disabled or uninstalled them?
Wait, how many antivirus programs do you have installed? You should only have 1. And you don't really install combofix because it doesn't show up in the add/remove programs list. It basically just copies some files to a directory and runs.
I have other programs such as Spybot search and destroy. Should that one, and other ones like it, be disabled too?
Spybot is fine to have installed even though its old and outdated. We only need to worry about actual antivirus software, such as nortons, mcafee, avg, avast and the like.
I see. Well, looking through the programs on my desktop, there doesn't seem to be anything that looks obviously like an antivirus, so should i be OK? If I were to run Combofix right now, is there a way to find out that it worked? Meaning find out that i disabled or uninstalled everything so that Combofix works out. Sorry if i sound vague.
Combofix will tell me what antivirus programs are installed and active. Also, when it first starts it will tell you that what antivirus programs are active and will tell you to close/disable them before continuing.
OK, so if i don't copy down the instructions you posted for Combofix, should it be OK if i just use common sense and just click through the steps? I mean it says at some point to not touch the computer at all while the program is running, for example. I want to be able to follow the steps accurately.
Lastly, i checked my Downloads folder, there isn't a way to change where downloads go on the bottom left. My OS is Windows XP, btw.
Is it even important to have the Combofix file on desktop? Why not just run it from the folder titled Downloads?
Once you see a screen similar to this then its scanning, just leave it alone.
If anything bad is detected, your system will reboot and it will continue to finish. If it does reboot, make sure you go back into safe mode since we don't know if it will freeze in regular mode. There is 50 stages so watch the output. At the end you will see it listing what its deleting if anything. It may not reboot though. When its done, you will get a log in notepad. That is the log that I need you to copy and paste in your reply.
Just like johnb35 said...wait for ComboFix to finish all the stages and be sure that every time a computer reboots,that you go in SAFE MODE WITH NETWORKING instead of leaving the computer going in the NORMAL MODE alone.
John, this is what popped up.
ComboFix 13-07-24.03 - g 07/24/2013 19:19:35.1.2 - x86 NETWORK
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2814.2488 [GMT -7:00]
Running from: c:\documents and settings\g\My Documents\Downloads\ComboFix.exe
AV: Microsoft Security Essentials *Disabled/Outdated* {EDB4FA23-53B8-4AFA-8C5D-99752CCA7095}
AV: Microsoft Security Essentials *Disabled/Updated* {BCF43643-A118-4432-AEDE-D861FCBCFCDF}
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
c:\documents and settings\All Users\Application Data\TEMP
c:\documents and settings\g\Application Data\PriceGong
c:\documents and settings\g\Application Data\PriceGong\Data\mru.xml
c:\documents and settings\g\WINDOWS
c:\windows\_detmp.2
c:\windows\_detmp.4
c:\windows\DXM18.tmp
c:\windows\DXM8.tmp
((((((((((((((((((((((((( Files Created from 2013-06-25 to 2013-07-25 )))))))))))))))))))))))))))))))
2013-07-14 03:02 . 2013-06-12 04:18 7068072 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{BBC3F6F4-C03B-43A1-ACF7-FDD05E187B77}\mpengine.dll
2013-07-13 01:28 . 2013-06-12 04:18 7068072 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\Backup\mpengine.dll
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2013-06-12 22:14 . 2012-08-19 07:16 692104 ----a-w- c:\windows\system32\FlashPlayerApp.exe
2013-06-12 22:14 . 2012-01-16 01:49 71048 ----a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
2013-05-02 15:28 . 2009-12-18 03:42 238872 ------w- c:\windows\system32\MpSigStub.exe
2013-05-01 10:59 . 2013-05-01 10:59 94208 ----a-w- c:\windows\system32\QuickTimeVR.qtx
2013-05-01 10:59 . 2013-05-01 10:59 69632 ----a-w- c:\windows\system32\QuickTime.qts
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"DWQueuedReporting"="c:\progra~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" [2007-08-24 437160]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\RunOnce]
"RunNarrator"="Narrator.exe" [2008-04-14 53760]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MsMpSvc]
@="Service"
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^McAfee Security Scan Plus.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk
backup=c:\windows\pss\McAfee Security Scan Plus.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^NETGEAR WG311T Smart Wizard.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\NETGEAR WG311T Smart Wizard.lnk
backup=c:\windows\pss\NETGEAR WG311T Smart Wizard.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^SBC Self Support Tool.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\SBC Self Support Tool.lnk
backup=c:\windows\pss\SBC Self Support Tool.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Wisdom-soft ScreenHunter 5.1 Free]
0 [X]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\AIM for Windows]
2012-12-05 22:41 2930288 ----a-w- c:\documents and settings\g\Local Settings\Application Data\AOL\AIM\aim.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\APSDaemon]
2013-04-22 04:43 59720 ----a-w- c:\program files\Common Files\Apple\Apple Application Support\APSDaemon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
2008-04-14 00:12 15360 ----a-w- c:\windows\system32\ctfmon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\CTxfiHlp]
2009-06-04 07:55 25600 ----a-w- c:\windows\system32\Ctxfihlp.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Google Update]
2011-04-24 02:09 136176 ----atw- c:\documents and settings\g\Local Settings\Application Data\Google\Update\GoogleUpdate.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IMJPMIG8.1]
2006-02-28 12:00 208952 ----a-w- c:\windows\ime\imjp8_1\imjpmig.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\iTunesHelper]
2013-05-31 18:56 152392 ----a-w- c:\program files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Motive SmartBridge]
2005-08-24 11:51 442455 ----a-w- c:\progra~1\SBCSEL~1\SMARTB~1\MotiveSB.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSC]
2012-03-27 00:08 931200 ----a-w- c:\program files\Microsoft Security Client\msseces.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSPY2002]
2006-02-28 12:00 59392 ----a-w- c:\windows\system32\IME\PINTLGNT\IMSCINST.EXE
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvCplDaemon]
2011-10-08 04:50 16744256 ----a-w- c:\windows\system32\nvcpl.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvMediaCenter]
2011-10-08 04:50 203072 ----a-w- c:\windows\system32\nvmctray.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\nwiz]
2011-10-08 04:50 1632360 ----a-w- c:\program files\NVIDIA Corporation\nView\nwiz.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PHIME2002A]
2006-02-28 12:00 455168 ----a-w- c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PHIME2002ASync]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
2013-05-01 10:59 421888 ----a-w- c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Samsung PanelMgr]
2010-06-07 10:57 618496 ----a-w- c:\windows\Samsung\PanelMgr\SSMMgr.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SigmatelSysTrayApp]
2005-03-22 21:20 339968 ----a-w- c:\windows\stsystra.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
2012-01-18 22:02 254696 ----a-w- c:\program files\Common Files\Java\Java Update\jusched.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\VolPanel]
2008-08-06 23:31 233576 ------w- c:\program files\Creative\Volume Panel\VolPanlu.exe
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"=
"c:\\WINDOWS\\system32\\usmt\\migwiz.exe"=
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"c:\\Program Files\\NVIDIA Corporation\\NVIDIA Updatus\\daemonu.exe"=
"c:\\Program Files\\Common Files\\Apple\\Apple Application Support\\WebKit2WebProcess.exe"=
"c:\\Program Files\\Bonjour\\mDNSResponder.exe"=
"c:\\Program Files\\iTunes\\iTunes.exe"=
S2 cpuz133;cpuz133;c:\windows\system32\drivers\cpuz133_x32.sys [6/8/2010 7:11 PM 20072]
S2 PCToolsSSDMonitorSvc;PC Tools Startup and Shutdown Monitor service;c:\program files\Common Files\PC Tools\sMonitor\StartManSvc.exe [12/24/2011 12:59 PM 793048]
S2 SSPORT;SSPORT;\??\c:\windows\system32\Drivers\SSPORT.sys --> c:\windows\system32\Drivers\SSPORT.sys [?]
S3 cpuz130;cpuz130;\??\c:\docume~1\g\LOCALS~1\Temp\cpuz130\cpuz_x32.sys --> c:\docume~1\g\LOCALS~1\Temp\cpuz130\cpuz_x32.sys [?]
S3 cpuz135;cpuz135;\??\c:\windows\TEMP\cpuz135\cpuz135_x32.sys --> c:\windows\TEMP\cpuz135\cpuz135_x32.sys [?]
S3 Creative Audio Engine Licensing Service;Creative Audio Engine Licensing Service;c:\program files\Common Files\Creative Labs Shared\Service\CTAELicensing.exe [7/15/2009 7:09 PM 79360]
S3 CT20XUT.SYS;CT20XUT.SYS;c:\windows\system32\drivers\CT20XUT.sys [6/4/2009 2:46 AM 171032]
S3 CT20XUT;CT20XUT;c:\windows\system32\drivers\CT20XUT.sys [6/4/2009 2:46 AM 171032]
S3 CTEXFIFX.SYS;CTEXFIFX.SYS;c:\windows\system32\drivers\CTEXFIFX.sys [6/4/2009 2:46 AM 1324056]
S3 CTEXFIFX;CTEXFIFX;c:\windows\system32\drivers\CTEXFIFX.sys [6/4/2009 2:46 AM 1324056]
S3 CTHWIUT.SYS;CTHWIUT.SYS;c:\windows\system32\drivers\CTHWIUT.sys [6/4/2009 2:46 AM 72728]
S3 CTHWIUT;CTHWIUT;c:\windows\system32\drivers\CTHWIUT.sys [6/4/2009 2:46 AM 72728]
S3 npggsvc;nProtect GameGuard Service;c:\windows\system32\GameMon.des -service --> c:\windows\system32\GameMon.des -service [?]
S3 psa805;Aurilium Sound Agent 2 (WDM);c:\windows\system32\drivers\psa805.sys --> c:\windows\system32\drivers\psa805.sys [?]
S3 QsndEnum;QSound Virtual Audio Devices Bus Enumerator;c:\windows\system32\DRIVERS\QsndEnum.sys --> c:\windows\system32\DRIVERS\QsndEnum.sys [?]
S3 ZCinema_TSHD;ZCinema TruSurround HD driver;c:\windows\system32\drivers\ZCinema_SRS_i386.sys [6/11/2009 6:04 PM 21392]
Contents of the 'Scheduled Tasks' folder
2013-07-15 c:\windows\Tasks\Adobe Flash Player Updater.job
- c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe [2012-08-19 22:14]
2013-07-12 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2011-06-02 00:57]
2013-07-14 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-1202660629-2111687655-725345543-1004Core.job
- c:\documents and settings\g\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2011-04-24 02:09]
2013-07-15 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-1202660629-2111687655-725345543-1004UA.job
2013-07-25 c:\windows\Tasks\Microsoft Antimalware Scheduled Scan.job
- c:\program files\Microsoft Security Client\MpCmdRun.exe [2012-03-27 00:03]
2013-07-25 c:\windows\Tasks\MpIdleTask.job
------- Supplementary Scan -------
uStart Page = hxxp://www.delta-search.com/?affID=119351&babsrc=HP_ss&mntrId=282E00123F7CF853
uSearchMigratedDefaultURL = hxxp://search.yahoo.com/search?p={searchTerms}&ei=utf-8&fr=b1ie7
uInternet Settings,ProxyOverride = <local>;*.local
uSearchURL,(Default) = hxxp://us.rd.yahoo.com/customize/ycomp/defaults/su/*http://www.yahoo.com
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office12\EXCEL.EXE/3000
TCP: DhcpNameServer = 192.168.0.1 68.94.157.1
DPF: Microsoft XML Parser for Java - file://c:\windows\Java\classes\xmldso.cab
FF - ProfilePath - c:\documents and settings\g\Application Data\Mozilla\Firefox\Profiles\pfehxcbq.default\
FF - prefs.js: browser.search.defaulturl - hxxp://aim.search.aol.com/aol/search?query={searchTerms}&invocationType=tb50-ff-aim-chromesbox-en-us&tb_uuid=100000000000000002&tb_oid=08-06-2010&tb_mrud=08-06-2010
FF - ExtSQL: !HIDDEN! 2009-11-07 20:51; {20a82645-c095-46ed-80e3-08825760534b}; c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension
FF - user.js: network.protocol-handler.warn-external.dnupdate - false);user_pref(network.protocol-handler.warn-external.dnupdate, false
FF - user.js: browser.sessionstore.resume_from_crash - false
FF - user.js: extensions.delta.tlbrSrchUrl -
FF - user.js: extensions.delta.id - 282e616f00000000000000123f7cf853
FF - user.js: extensions.delta.appId - {C26644C4-2A12-4CA6-8F2E-0EDE6CF018F3}
FF - user.js: extensions.delta.instlDay - 15866
FF - user.js: extensions.delta.vrsn - 1.8.21.5
FF - user.js: extensions.delta.vrsni - 1.8.21.5
FF - user.js: extensions.delta.vrsnTs - 1.8.21.519:28
FF - user.js: extensions.delta.prtnrId - delta
FF - user.js: extensions.delta.prdct - delta
FF - user.js: extensions.delta.aflt - babsst
FF - user.js: extensions.delta.smplGrp - none
FF - user.js: extensions.delta.tlbrId - base
FF - user.js: extensions.delta.instlRef - sst
FF - user.js: extensions.delta.dfltLng - en
FF - user.js: extensions.delta.excTlbr - false
FF - user.js: extensions.delta.ffxUnstlRst - true
FF - user.js: extensions.delta.admin - false
FF - user.js: extensions.delta_i.babTrack - affID=119351
FF - user.js: extensions.delta_i.babExt -
FF - user.js: extensions.delta_i.srcExt - ss
FF - user.js: extensions.delta.autoRvrt - false
FF - user.js: extensions.delta.rvrt - false
FF - user.js: extensions.delta.newTab - false
- - - - ORPHANS REMOVED - - - -
MSConfigStartUp-ROC_roc_ssl_v12 - c:\program files\AVG Secure Search\ROC_roc_ssl_v12.exe
MSConfigStartUp-SDTray - c:\program files\Spybot - Search & Destroy 2\SDTray.exe
AddRemove-NVIDIA Display Control Panel - c:\program files\NVIDIA Corporation\Uninstall\nvuninst.exe
AddRemove-NVIDIA nView Desktop Manager - c:\program files\NVIDIA Corporation\nView\nViewSetup.exe
AddRemove-Trillian - c:\program files\Trillian\Trillian.exe
catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2013-07-24 19:25
Windows 5.1.2600 Service Pack 3 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\npggsvc]
"ImagePath"="c:\windows\system32\GameMon.des -service"
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_USERS\S-1-5-21-1202660629-2111687655-725345543-1004\Software\SecuROM\License information*]
"datasecu"=hex:ee,cc,37,b2,f8,65,b3,db,a9,1f,83,a0,66,3d,56,f3,3c,de,85,3a,42,
01,cf,46,d0,88,ee,35,bd,1e,db,54,ec,0a,8f,4a,61,21,ae,1d,aa,02,c9,9a,09,22,\
"rkeysecu"=hex:3c,a4,20,7f,1e,80,4b,0a,97,fe,51,b5,a2,01,1c,11
Completion time: 2013-07-24 19:26:54
ComboFix-quarantined-files.txt 2013-07-25 02:26
Pre-Run: 30,922,616,832 bytes free
Post-Run: 31,450,591,232 bytes free
WindowsXP-KB310994-SP2-Home-BootDisk-ENU.exe
[boot loader]
timeout=2
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
c:\cmdcons\BOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
UnsupportedDebug="do not select this" /debug
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
- - End Of File - - ACD534A390069496E931F5DF88578A94
8F558EB6672622401DA993E1E865C861
Are you able to start your pc in regular mode without it freezing? Would like for you to post a log that combofix produced but didn't show you. Navigate to here.
c:\Qoobox
and in that folder will be a file named add-remove programs.txt Open that file and copy and paste the contents back here.
I posted the Combofix log, didn't I?
Here is the stuff from the stuff from add-remove programs.txt.
Acrobat.com
Adobe AIR
Adobe Flash Player 11 Plugin
Adobe Shockwave Player 11.6
AIM for Windows
Apple Mobile Device Support
Bonjour
Combined Community Codec Pack 2008-09-21 16:18
Compatibility Pack for the 2007 Office system
CPUID HWMonitor 1.16
Creative Audio Control Panel
Creative Console Launcher
Creative Software AutoUpdate
Creative WaveStudio 7
Critical Update for Windows Media Player 11 (KB959772)
Diablo II
DriverTuner 3.0.1.0
Google Chrome
High Definition Audio Driver Package - KB835221
Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)
Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)
Hotfix for Windows Media Format 11 SDK (KB929399)
Hotfix for Windows Media Player 11 (KB939683)
Hotfix for Windows XP (KB2158563)
Hotfix for Windows XP (KB2443685)
Hotfix for Windows XP (KB2570791)
Hotfix for Windows XP (KB2633952)
Hotfix for Windows XP (KB942288-v3)
Hotfix for Windows XP (KB952287)
Hotfix for Windows XP (KB954550-v5)
Hotfix for Windows XP (KB961118)
Hotfix for Windows XP (KB970653-v3)
Hotfix for Windows XP (KB976098-v2)
Hotfix for Windows XP (KB979306)
Hotfix for Windows XP (KB981793)
Intel(R) PRO Network Connections Drivers
InterActual Player
iTunes
Java Auto Updater
Java(TM) 6 Update 31
LG USB Modem Drivers
Lizardtech DjVu Control
Maintenance Samsung ML-191x 252x Series
Media Player Classic - Home Cinema v. 1.3.1249.0
Microsoft .NET Framework 2.0 Service Pack 2
Microsoft .NET Framework 3.0 Service Pack 2
Microsoft Application Error Reporting
Microsoft Compression Client Pack 1.0 for Windows XP
Microsoft Internationalized Domain Names Mitigation APIs
Microsoft Kernel-Mode Driver Framework Feature Pack 1.5
Microsoft National Language Support Downlevel APIs
Microsoft Office Professional Edition 2003
Microsoft Silverlight
Microsoft User-Mode Driver Framework Feature Pack 1.0
Microsoft VC9 runtime libraries
Microsoft Visual C++ 2005 Redistributable
Microsoft Visual C++ 2005 Redistributable - KB2467175
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
Mozilla Firefox 22.0 (x86 en-US)
Mozilla Maintenance Service
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
NETGEAR WG311T Wireless Adapter
NVIDIA Control Panel 285.58
NVIDIA Graphics Driver 285.58
NVIDIA Install Application
NVIDIA nView 135.95
NVIDIA Update 1.5.20
NVIDIA Update Components
OpenAL
PC Tools Registry Mechanic 11.0
QuickTime
Security Update for CAPICOM (KB931906)
Security Update for Microsoft .NET Framework 3.5 SP1 (KB2604111)
Security Update for Microsoft .NET Framework 3.5 SP1 (KB2657424)
Security Update for Microsoft Windows (KB2564958)
Security Update for Windows Internet Explorer 7 (KB938127-v2)
Security Update for Windows Internet Explorer 7 (KB958215)
Security Update for Windows Internet Explorer 7 (KB960714)
Security Update for Windows Internet Explorer 7 (KB961260)
Security Update for Windows Internet Explorer 7 (KB963027)
Security Update for Windows Internet Explorer 7 (KB969897)
Security Update for Windows Internet Explorer 7 (KB972260)
Security Update for Windows Internet Explorer 8 (KB2183461)
Security Update for Windows Internet Explorer 8 (KB2360131)
Security Update for Windows Internet Explorer 8 (KB2416400)
Security Update for Windows Internet Explorer 8 (KB2482017)
Security Update for Windows Internet Explorer 8 (KB2497640)
Security Update for Windows Internet Explorer 8 (KB2510531)
Security Update for Windows Internet Explorer 8 (KB2530548)
Security Update for Windows Internet Explorer 8 (KB2544521)
Security Update for Windows Internet Explorer 8 (KB2559049)
Security Update for Windows Internet Explorer 8 (KB2586448)
Security Update for Windows Internet Explorer 8 (KB2618444)
Security Update for Windows Internet Explorer 8 (KB2647516)
Security Update for Windows Internet Explorer 8 (KB2675157)
Security Update for Windows Internet Explorer 8 (KB2699988)
Security Update for Windows Internet Explorer 8 (KB971961)
Security Update for Windows Internet Explorer 8 (KB972260)
Security Update for Windows Internet Explorer 8 (KB974455)
Security Update for Windows Internet Explorer 8 (KB976325)
Security Update for Windows Internet Explorer 8 (KB978207)
Security Update for Windows Internet Explorer 8 (KB981332)
Security Update for Windows Internet Explorer 8 (KB982381)
Security Update for Windows Media Player (KB2378111)
Security Update for Windows Media Player (KB952069)
Security Update for Windows Media Player (KB954155)
Security Update for Windows Media Player (KB968816)
Security Update for Windows Media Player (KB973540)
Security Update for Windows Media Player (KB975558)
Security Update for Windows Media Player (KB978695)
Security Update for Windows Media Player 11 (KB936782)
Security Update for Windows Media Player 11 (KB954154)
Security Update for Windows XP (KB2079403)
Security Update for Windows XP (KB2115168)
Security Update for Windows XP (KB2121546)
Security Update for Windows XP (KB2160329)
Security Update for Windows XP (KB2229593)
Security Update for Windows XP (KB2259922)
Security Update for Windows XP (KB2279986)
Security Update for Windows XP (KB2286198)
Security Update for Windows XP (KB2296011)
Security Update for Windows XP (KB2296199)
Security Update for Windows XP (KB2347290)
Security Update for Windows XP (KB2360937)
Security Update for Windows XP (KB2387149)
Security Update for Windows XP (KB2393802)
Security Update for Windows XP (KB2412687)
Security Update for Windows XP (KB2419632)
Security Update for Windows XP (KB2423089)
Security Update for Windows XP (KB2436673)
Security Update for Windows XP (KB2440591)
Security Update for Windows XP (KB2443105)
Security Update for Windows XP (KB2476490)
Security Update for Windows XP (KB2476687)
Security Update for Windows XP (KB2478960)
Security Update for Windows XP (KB2478971)
Security Update for Windows XP (KB2479628)
Security Update for Windows XP (KB2479943)
Security Update for Windows XP (KB2481109)
Security Update for Windows XP (KB2483185)
Security Update for Windows XP (KB2485376)
Security Update for Windows XP (KB2485663)
Security Update for Windows XP (KB2503658)
Security Update for Windows XP (KB2503665)
Security Update for Windows XP (KB2506212)
Security Update for Windows XP (KB2506223)
Security Update for Windows XP (KB2507618)
Security Update for Windows XP (KB2507938)
Security Update for Windows XP (KB2508272)
Security Update for Windows XP (KB2508429)
Security Update for Windows XP (KB2509553)
Security Update for Windows XP (KB2511455)
Security Update for Windows XP (KB2524375)
Security Update for Windows XP (KB2535512)
Security Update for Windows XP (KB2536276-v2)
Security Update for Windows XP (KB2536276)
Security Update for Windows XP (KB2544893-v2)
Security Update for Windows XP (KB2544893)
Security Update for Windows XP (KB2555917)
Security Update for Windows XP (KB2562937)
Security Update for Windows XP (KB2566454)
Security Update for Windows XP (KB2567053)
Security Update for Windows XP (KB2567680)
Security Update for Windows XP (KB2570222)
Security Update for Windows XP (KB2570947)
Security Update for Windows XP (KB2584146)
Security Update for Windows XP (KB2585542)
Security Update for Windows XP (KB2592799)
Security Update for Windows XP (KB2598479)
Security Update for Windows XP (KB2603381)
Security Update for Windows XP (KB2618451)
Security Update for Windows XP (KB2619339)
Security Update for Windows XP (KB2620712)
Security Update for Windows XP (KB2621440)
Security Update for Windows XP (KB2624667)
Security Update for Windows XP (KB2631813)
Security Update for Windows XP (KB2633171)
Security Update for Windows XP (KB2639417)
Security Update for Windows XP (KB2641653)
Security Update for Windows XP (KB2646524)
Security Update for Windows XP (KB2647518)
Security Update for Windows XP (KB2653956)
Security Update for Windows XP (KB2655992)
Security Update for Windows XP (KB2659262)
Security Update for Windows XP (KB2660465)
Security Update for Windows XP (KB2661637)
Security Update for Windows XP (KB2676562)
Security Update for Windows XP (KB2685939)
Security Update for Windows XP (KB2686509)
Security Update for Windows XP (KB2691442)
Security Update for Windows XP (KB2695962)
Security Update for Windows XP (KB2698365)
Security Update for Windows XP (KB2707511)
Security Update for Windows XP (KB2709162)
Security Update for Windows XP (KB2718523)
Security Update for Windows XP (KB2719985)
Security Update for Windows XP (KB923561)
Security Update for Windows XP (KB938464)
Security Update for Windows XP (KB941569)
Security Update for Windows XP (KB946648)
Security Update for Windows XP (KB950762)
Security Update for Windows XP (KB950974)
Security Update for Windows XP (KB951066)
Security Update for Windows XP (KB951376-v2)
Security Update for Windows XP (KB951698)
Security Update for Windows XP (KB951748)
Security Update for Windows XP (KB952004)
Security Update for Windows XP (KB952954)
Security Update for Windows XP (KB953155)
Security Update for Windows XP (KB954211)
Security Update for Windows XP (KB954459)
Security Update for Windows XP (KB954600)
Security Update for Windows XP (KB955069)
Security Update for Windows XP (KB956391)
Security Update for Windows XP (KB956572)
Security Update for Windows XP (KB956744)
Security Update for Windows XP (KB956802)
Security Update for Windows XP (KB956803)
Security Update for Windows XP (KB956841)
Security Update for Windows XP (KB956844)
Security Update for Windows XP (KB957097)
Security Update for Windows XP (KB958644)
Security Update for Windows XP (KB958687)
Security Update for Windows XP (KB958690)
Security Update for Windows XP (KB958869)
Security Update for Windows XP (KB959426)
Security Update for Windows XP (KB960225)
Security Update for Windows XP (KB960715)
Security Update for Windows XP (KB960803)
Security Update for Windows XP (KB960859)
Security Update for Windows XP (KB961371)
Security Update for Windows XP (KB961373)
Security Update for Windows XP (KB961501)
Security Update for Windows XP (KB968537)
Security Update for Windows XP (KB969059)
Security Update for Windows XP (KB969898)
Security Update for Windows XP (KB969947)
Security Update for Windows XP (KB970238)
Security Update for Windows XP (KB970430)
Security Update for Windows XP (KB971468)
Security Update for Windows XP (KB971486)
Security Update for Windows XP (KB971557)
Security Update for Windows XP (KB971633)
Security Update for Windows XP (KB971657)
Security Update for Windows XP (KB972270)
Security Update for Windows XP (KB973346)
Security Update for Windows XP (KB973354)
Security Update for Windows XP (KB973507)
Security Update for Windows XP (KB973525)
Security Update for Windows XP (KB973869)
Security Update for Windows XP (KB973904)
Security Update for Windows XP (KB974112)
Security Update for Windows XP (KB974318)
Security Update for Windows XP (KB974392)
Security Update for Windows XP (KB974571)
Security Update for Windows XP (KB975025)
Security Update for Windows XP (KB975467)
Security Update for Windows XP (KB975560)
Security Update for Windows XP (KB975561)
Security Update for Windows XP (KB975562)
Security Update for Windows XP (KB975713)
Security Update for Windows XP (KB977165)
Security Update for Windows XP (KB977816)
Security Update for Windows XP (KB977914)
Security Update for Windows XP (KB978037)
Security Update for Windows XP (KB978251)
Security Update for Windows XP (KB978262)
Security Update for Windows XP (KB978338)
Security Update for Windows XP (KB978542)
Security Update for Windows XP (KB978601)
Security Update for Windows XP (KB978706)
Security Update for Windows XP (KB979309)
Security Update for Windows XP (KB979482)
Security Update for Windows XP (KB979559)
Security Update for Windows XP (KB979683)
Security Update for Windows XP (KB979687)
Security Update for Windows XP (KB980195)
Security Update for Windows XP (KB980218)
Security Update for Windows XP (KB980232)
Security Update for Windows XP (KB980436)
Security Update for Windows XP (KB981322)
Security Update for Windows XP (KB981852)
Security Update for Windows XP (KB981957)
Security Update for Windows XP (KB981997)
Security Update for Windows XP (KB982132)
Security Update for Windows XP (KB982214)
Security Update for Windows XP (KB982665)
Security Update for Windows XP (KB982802)
SigmaTel Audio
swMSM
System Checkup 3.0
System Requirements Lab
Trillian
UltraISO Premium V9.35
Update for Microsoft .NET Framework 3.5 SP1 (KB963707)
Update for Windows Internet Explorer 8 (KB972636)
Update for Windows Internet Explorer 8 (KB976662)
Update for Windows Internet Explorer 8 (KB976749)
Update for Windows Internet Explorer 8 (KB980182)
Update for Windows XP (KB2141007)
Update for Windows XP (KB2345886)
Update for Windows XP (KB2467659)
Update for Windows XP (KB2541763)
Update for Windows XP (KB2607712)
Update for Windows XP (KB2616676)
Update for Windows XP (KB2641690)
Update for Windows XP (KB2718704)
Update for Windows XP (KB951978)
Update for Windows XP (KB955759)
Update for Windows XP (KB955839)
Update for Windows XP (KB967715)
Update for Windows XP (KB968389)
Update for Windows XP (KB971029)
Update for Windows XP (KB971737)
Update for Windows XP (KB973687)
Update for Windows XP (KB973815)
Volume Panel
WebFldrs XP
Windows Genuine Advantage Validation Tool (KB892130)
Windows Media Format 11 runtime
Windows PowerShell(TM) 1.0
Windows XP Service Pack 3
WinRAR archiver
