ASRock Extreme4 Motherboard Graphics Problem
Kirrick
I recently built a new computer (3 days ago) and I'm having an issue with the graphics on the motherboard. I looked online and it says that the the graphacs are supported only by CPU with integrated graphic. I'm running with an Intel Core i7 3770 with HD graphics 4000. I have installed all the drivers online and I still can't play any games and whatnot.
Here are my specs if you need them:
Intel Core i7 3770 @ 3.4 GHz
ASRock Extreme4 LGA 1155 Motherboard
G.Skill Ripjawz X 16 GB DDR3 RAM
I currently do not have a graphics card for the build. In about a week or two, I am going to get a Geforce GTX 760.
Any help is appreciated.
Thanks.
That's odd. I guess everything works on your PC but the games?
Do you have direct x and/or open gl?
What specific games are crashing?
Every single game is crashing, saying it is bad video drivers when really it is the V-RAM. I have gone into the bios and set the amount to 1024 MB, but it has not done anything, and my computer still says I have none.
