USB Header to Regular USB
ZeroSec
<SOLVED> USB Header to Regular USB
So first of all i apologize if i made this thread in the wrong place or anything of that sort, this is my first post here (or on any forum for that matter) and don't want to offend anyone, so mods feel free to move this post if necessary.
I have searched long and hard for finding what I'am looking for, basically I have a internal card reader / usb hub that would normally connect to a 8/9 pin header on my mobo, for lack of willingness to go out and buy a usb card reader, and I'm fairly certain that i have all the tools to do this, I want to convert it from being a mobo pin connector to a standard usb plug that i can connect to any external usb port.
Tl;Dr:
My problem is that the card reader has 8 wires, and a USB only has 4. So if someone could either point me in the right direction or tell me I'm stupid for not wanting to spend the 20$ to buy one, that would be astounding. Cheers
-Brandon
Is this what your talking about? To plug the reader into and then plug into the USB on the back of the computer, instead of internal.
Sort of, this is what it is
FaOIKAAea
I basically need a wiring diagram of which of the 8 wires connects to which of the 4 USB wires
Well most USB wires I have seen are either Red/Yellow/Green and Black or Red/White/Green and Black.
Edit.
Since you have the reader with the USB header connector, if it has 8 wires each side is a single USB connector. Should be pretty easy to match them up.
the card readers wires are, black, black, blue, green, yellow, white, red, orange.
Do just the black, red, white, and green wire's go to a usb, or? :confused:
Would have been easier before you cut the end off, lol. Could have just matched one side. My guess is just match the black/Green/White/Red, like you said.
The connector was for a double pin motherboard header
So that means there are useless wires?
Just tried what you said, the usb input on the card reader works, the card reader slots don't. Any ideas?
It's obviously the extra 3 wires, the question is where do they go
(Orange, Blue, & Yellow)
Trace the wires back up to the connector on the card. Match the wires up to the ones on the otherside in the same order.
Orange = Red, Yellow = White, Blue = Green.
I'll try out this theory tomorrow afternoon and post back here weather it's been solved or not.
Cheers for your help so far!
If you still have the USB header connector you can find out what color wires go to what pin on the USB header. Once u find that out report back with your findings. You might need an ohm meter to find out.
Alright heres what i just tried,
Red+Orange - Red, Black - Black, Blue+Green - Green, Yellow+White - White.
When i plug it in to my computer, it says "usb device not recognized" (this is with and without a sd card + usb device plugging into it)
Any other ideas on combinations?
NOTE, I am fairly certain that orange is also a positive hot wire as with closer inspection it appears the red, orange, and black wires are a slightly lower gauge then all other wires.
@CorruptHawkeyez The way that it is laid out on the header is as follows
from left to right
top:empty, shield, green, white, red.
Bottom:empty, shield+ground, blue, yellow, orange.
You need 2 USB plugs for starters.
On the first one try:
card reader > USB cable
red > red
white > white
green > green
shield > black
2nd USB cable:
orange > red
yellow > white
blue > green
shield > black
You may have to have both plugged in before you startup your PC.
red > red
white > white
green > green
shield > black
2nd USB cable:
orange > red
yellow > white
blue > green
shield > black
Sweetas, Just used one usb cable, don't care about the usb port on the card reader anyway. so i used the
orange > red
yellow > white
blue > green
shield > black
scheme and it works all good. Cheers for your help!
Just out of curiosity, Why wouldn't it work with just one usb?
And i apologize but how do i mark this as [solved]?
Here are some pictures of the end result if anyone cares.
And I ran out of heat shrink, didn't do it to look "cool" or something.
