Need help!!
GingerLord
Hello, guys!
My current video-card is an Evga Geforce GTX 660 Ti 2gb, and I am currently only using one monitor, but I want to expand to three monitors. The question I want to ask you about is if my video-card can handle all three monitors, and if it can, can it do it with high solution at all monitors? Or do I have to buy a new videocard, making it SLI? Please comment if you can help me, or if you dont understand what I need help with..
Yes you can do 3 monitors. You can use the 2 dvi ports plus one monitor must use the display port connection on the video card. If the monitor doesn't support display port then you will need an active display port to dvi adapter to convert the signal.
But will it run smoothly?
If doing intensive gaming you may have an issue. If so, would suggest a 3gb card instead.
