tylerjrb
Received a new mobo today for my computer, its my first build and the first part to go into the case. it is an asus p8z77-v pro board, 3rd one ive had to buy, one was not the same board so i had to refund and one the guy said the cpu socket was fine and the pins were bent when i got it, further more he wont refund me... so i can try that board incase its the case.
anyway this was is a new board also from a seller on eBay and it looks great, socket pins are perfect. i installed into my corsair carbide 500r case and it all aligned well with the standoffs in the case (following all instructions). i didn't over tighten them i just sort of tightened until it stopped and went a little further to secure them in opposites around the board. After i had installed it i noticed the back ports were not in line with the io shield, they are completely through but really far down on the bottom headphone, mic jacks. but at the top it seems to be level, i made sure when installing the mobo it was pushed back and all standoffs lined up correctly. it seems like the mobo is too far in or like the standoffs are too small or something but only really on the bottom ports. looking at the board it looks level in the case and looks fine the only problems i can kind of see is some of the screws look a little off center in the mount holes.
there is also a standoff central on the mobo which from the back doesnt look like its tightened all the way to the tray and you can see this in the pictures. its not quite touching the mobo correctly. i will proberly have to take the mobo back out to tighten the standoff in correctly but was wondering why its like this at the bottom is it because of this standoff or the mobo is bent or something or the IO shield is bent although that looks ok. it seems ok at the top usb ports etc but not lower down on the usb 3 ports and headphone/mic jacks. maybe i havent secured the standoffs properly in the tray.
but futher more if it is bent will it still work properly, i can get access to all of the ports but just wondered if it would still work correctly. as you cant really see it from the back etc.
PHOTOS
as you can see top ports are pretty much level.
standoff not correctly fit in as you can see there is a bit above the standoff which i guess fits into the motherboard hole?
bottom ports as you can see quite badly out of alignment.
bottom dvi and vga out ports the dvi looks out of alignment whereas the vga looks central to the io shield.
some screws are like this one, a bit off center but they are the correct screws.
any help will be greatly appreciated on what i need to do. regards, Tyler.b
PHOTOS
