I have a custom built computer and it just shuts down randomly and then stay off for 3-5secs an turns back on then works for 3secs (no display) and back off...
I thought it was the bad ram because I had 3 sticks (2 in pc) and then if my computer shut off like that I would put other stick in there an then it worked(at least I think but it may be that while i switched the ram the too heated component got time too cool if the heat is the problem,also sometimes switching ram sticks didnt work so I bought new patriot viper 8gb and put it in and it was fine until today (1 day after)it shuts down on me again while using C4D and photoshop.I think the problem is either power or heat(aldo I did vacuum the fans..)
Thanks
Intel core i5 3450S
Asrock h67M
8gb patriot viper ram
Hdd i took from my laptop (may be causing problems ?)
Dvd drive
400w old PSU (too little power?)
Thanks
Intel core i5 3450S
Asrock h67M
Dvd drive
