tylerjrb
hey guys!, my brother has a old corsair tx750w psu from his old computer and has said I could have it. Currently ive just done some testing using the paper clip test and got my two front 140mm fans to work fine using a Molex. the only problem is the psu fan itself does not work therefore if I powered my whole system it would proberly overheat the psu.
the PSU works fine and as I don't have any receipts dates etc, I doubt I could return it to corsair its a couple of years old. I was wondering if there was any huge danger to open the psu case up and have a look at how the fan is connected. and then depending on how it is connected replace the fan for a new one. (if that is at all possible). I just don't want to spend £90 on a new power supply id rather have a go at repairing or replacing the current fan as that is a much cheaper alternative as the psu itself runs fine.
How do I discharge the capacitors too as they look pretty scary, do I just need to press the on and off button loads of times on the psu itself or do I need to do something complicated, or can I just leave them entirely alone.
Or... do you strongly go against me attempting this. I at least want to have a look at the connection to see if its connected correctly. Id rather replace the fan as to send it to corsair it would cost me more than to replace the fan itself.
Any help appreciated!, thanks guys.
Tylerjrb.
Tylerjrb.
