Fatal error: One or more table pointers are invalid
SiicKx
Hello, i just upgraded my hardware to an I5 4670k, Gigabyte Z87 Mobo, 8 gb G skill DDR3, Corsair 750w PSU, and Raedon 7870 GPU. Everything seems to be working well, except on every boot up I get a message-
"Fatal error: One or more table pointers are invalid. Modification could be unsafe... Press any key to continue boot"
My harddrive is my old IDE format hard drive, and the guy who installed my components had to use an IDE to SATA adapter.
What is this table pointer error, is it dangerous/critical, and how can I solve this because it it bothersome to have to press enter on every boot. Thanks for any help.
Did you do a fresh install of windows? Those Sata to IDE adapters usually don't work very well, I would suggest to buy to a Sata hard drive and do a fresh install of windows and you should be fine.
