tylerjrb
hi guys, got my first pc build running but so far its not going well with regards to installing windows 8 64bit. i get the the install streen put the product code in etc and it starts to install. about 60-70% through the installation it comes up with the error message 0x80070570 aswell as saying "windows cannot install required files. the file may be corrupt or missing. make sure that all files required for installation are available and restart the installation".
and then the pc restarts. ive tried with different sets of ram ie, 2 sticks at a time, 1 stick at a time and 4 at a time and the same still occurs. also theres no specific percentage it stops at its just usually around the 60-71% mark and the pc restarts. ive tried this several times but the same keeps happening.
Im also installing it from disk so i cannot go to the desktop obviously or anything like that. ive looked around and havent really found a solid answer and was wondering if anyone could help me as im really annoyed that i cannot get it to work.
EDIT: it has also come up with "your pc has encountered a problem" with a big sad face on the screen it than says collection error data and restarts.
it also come up saying that i cannot install because of some partition format on the SSD and i have to restart to get it to work again. it also comes up sometimes with an operating system was not found ctrl + alt + del to restart. this is usually after press any key to boot from cd or dvd.
i have a 120gb kingston hyper x 3k SSD
installing windows 8 64 bit.
EDIT: it wont even complete, preparing files anymore without the same error message. this is the first installation step.
EDIT A BIT MORE: its now on getting files ready for installation but get the same error message at about 3% now as it shut off preparing files at about 3% also. i removed the previous attempt partitions and it didnt get very far, about 3% as stated above on the first step "copying files" it then went onto getting files ready for installation and again at about 3% it came up with your pc encountered a problem and restarted. no error message this time.
