Best value monitor ?
jamesd1981
Hey guys looking for some opinions on which of these 3 are the best value.
first one is by far the cheapest, decent size, but slower refresh 5ms.
http://www.scan.co.uk/products/23-a...hdmi-dvi-vga-1366x768-200cd-m-100m1-5ms-black
second one is a benq slightly bigger and higher spec 2ms and built in speakers
http://www.amazon.co.uk/BenQ-GL2450...=UTF8&qid=1381514988&sr=8-1&keywords=gl2450hm
Third is a liyama very similar spec and size to the benq
http://www.cclonline.com/product/12...Prolite-E2483HS-B1-24-Black-LED-HDMI/MON2343/
I have has plenty of acers and always found the reliable, but never owned either benq or liyama are they good brands ?
Definitely go for the Iiyama! They are fantastic monitors. I love my Iiyama ProLite E2409HDS - had it two years now, it's great. I have used some of Iiyama's newer monitors too and they're great too, so I would go for it!
You think it is worth the £30 extra on the lower spec acer ?
Is there any noticeable difference between 5 ms and 2 ms, never had a 2 ms monitor ?
2ms is better for gaming I think.
The picture quality of the Iiyamas are great. I've used a lot of their monitors now (we have two in our household and Dad sells them) and the picture quality on all of the ones I have used is fantastic. Bright, crisp and clear.
Yep. Lower is better for games. 5ms or less seems to be the general range for gaming.
I can't comment on the brand, I've never used one before. Spirit seems to like them so It would be a good choice.
Yeah I thought so, that was one of the reasons why I got my Iiyama - even though I'm not really a gamer haha. ;)
Iiyamas don't appear to be readily available in the States, but they can be bought over here in the UK.
They're good monitors. :good:
