Thank you everyone for your advice. I think I'll hold out another year until I go to uni to get a decent machine.
1. Get yourself the
largest fastest USB drive you own or can buy (8GB is plenty) and enable
ready-boost. This feature is designed to act as proxy RAM, where the USB 2.0 interface is many times faster than HDD access for random writes and page file access. Essentially in lay-man's terms it uses USB stick as RAM (not technically correct). Your use-case is what Ready Boost was designed for.
Ready Boost instructions here. Minimum 256MB USB stick (requires a minimum speed), but really, try any and everything you have. Dedicate the USB stick to the Ready Boost function and leave it in the machine.
2.
Defragment your hard drive. A new Windows install will be very much fragmented. Use
Auslogic Defragmenter here. A new Windows installation will also thrash the HDD (slowing it down) whilst indexing, so ensure that has completed. Leave the machine on over night and defrag again in the morning.
3. In the start button search field type:
msconfig
In the
Services Tab, enable the
'Hide Microsoft Services' radio button at the bottom and deselect anything that isn't critical to your machine operating (i.e. NOT graphics drivers). Disable any adobe, apple, flash, and so on. This stuff slows down your computer and uses RAM unnecessarily. The service(s) will start if and when you need them.
In the same MSCONFIG applet, go to the
Startup tab and uncheck anything that you absolutely don't need to start as soon as windows start.
4.
Right click on Computer and select
Properties. Click on
Advanced system settings in the left pane and select performance
'settings'. Select the
'Adjust for best performance' option. Then select the
Advanced Tab and under
Virtual Memory, select
Change, and ensure the page file is
custom size fixed on
initial and
maximum size for the recommended amount (prevents further defragmentation).
5. Restart your computer. You should see a significant improvement.
6. Once you have done all that,
go here and make sure you have all the latest chipset driver.
7. Restart your machine once more.
