What hard drive shall I buy?
alexjb
Hi everyone :)
I really need to get a new hard drive for my computer with at least 1TB of space, but the problem is that I can only afford to spend about £55 and I'm not really sure which one to go for, I do not understand what all the specs mean but I think this one looks really good?
http://www.ebuyer.com/319639-seagat...ard-drive-oem-st1000dm003#product-description
Please can somebody recommend a hard drive? also the more space the better, might be willing to pay a bit more somehow if I can, if its a good deal :)
That's exactly the drive I'd recommend. Go for it!
awesome thanks! :) I thought that it looked really good, but my friend said that I should only buy a Western Digital hard drive, is this a better one?
Also just wondering, do I need to buy a Sata cable or do they usually come with one?
Thanks! :)
If it's OEM like the one posted you may, but your motherboard should have come with some (I remember helping you about a year ago to build your first PC. ;) ) Check and see if you have any left over and if not just buy one.
The Seagate drives are good, I'd go for it.
Awesome thanks hopefully I have one somewhere, I put all of the boxes somewhere safe so I will have a look in them later :) and also I cannot thank you enough for all your help last year lol :) me and my brother are so glad, because without your help we would not have had this pc and all my friends want to build a computer and are asking me to help them but I said join computerforums lol :) but I learnt a lot about how to build them now through your help thanks :)
No problem Alex, pleased you and your brother have learned some new skills and are enjoying your gaming rig. I'm also pleased it's still all working OK! :good:
thanks :) its working really really well :) and the games on the computer are so cheap compared to our xbox! :)
